I’m trying to build CMAQ on a cluster and am near the end of the build (trying to compile CCTM). Unfortunately the build stalls after giving the following errors:
The message is self-explanatory. You are choosing compiler options that are not recognized by the PGI compiler.
You appear to be using a makefile configured for the Intel compiler. You either have to select a configuration suited to the PGI compiler, if one is provided in the makefile, or modify the makefile yourself.
Even worse, if there are options that are recognized by both the compilers but with different meanings, you may not get the best executable program, as one aims to produce quite often.
