I was trying to run the CV example tlt notebook: detectnet_v2.ipynb
It shows the following error when running to the command:
!tlt detectnet_v2 dataset_convert
-d $SPECS_DIR/detectnet_v2_tfrecords_kitti_trainval.txt
-o $DATA_DOWNLOAD_DIR/tfrecords/kitti_trainval/kitti_trainval
Converting Tfrecords for kitti trainval dataset
2021-02-22 16:27:43,228 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the "user":"UID:GID" in the
DockerOptions portion of the ~/.tlt_mounts.json file. You can obtain your
users UID and GID by using the "id -u" and "id -g" commands on the
terminal.
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
2021-02-22 23:27:50,365 - iva.detectnet_v2.dataio.build_converter - INFO - Instantiating a kitti converter
2021-02-22 23:27:50,365 - iva.detectnet_v2.dataio.dataset_converter_lib - INFO - Creating output directory /workspace/tlt-experiments/data/tfrecords/kitti_trainval
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/dataset_convert.py", line 90, in <module>
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/dataset_convert.py", line 85, in main
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataio/build_converter.py", line 76, in build_converter
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataio/kitti_converter_lib.py", line 76, in __init__
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataio/dataset_converter_lib.py", line 57, in __init__
File "/usr/lib/python3.6/os.py", line 210, in makedirs
makedirs(head, mode, exist_ok)
File "/usr/lib/python3.6/os.py", line 220, in makedirs
mkdir(name, mode)
FileNotFoundError: [Errno 2] No such file or directory: '/workspace/tlt-experiments/data/tfrecords'
File "/usr/local/bin/detectnet_v2", line 8, in <module>
sys.exit(main())
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/entrypoint/detectnet_v2.py", line 12, in main
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/entrypoint/entrypoint.py", line 296, in launch_job
AssertionError: Process run failed.
2021-02-22 16:27:51,261 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
I’m not sure what happened inside after the script open the docker container and why makedirs is giving this error. Is it because I’m running the docker as root? (I am pretty sure on the outside I add the user to docker group and that’s why I don’t need to use sudo to run the command)
And if I need to change it to user, how? It tells me to add the “user”:“UID:GID” to config file, but how exactly do I do this? Im not familiar with config docker with JSON, Can you provide a JSON example that include USER UID:GID?
Please give me some pointers. Thanks!
