I had a problem to install tensorflow.
The error message is like below.
Please help me.
user@user-desktop:~$ pip3 install --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v42 tensorflow-gpu==1.13.1+nv19.3 --user
WARNING: The directory ‘/home/user/.cache/pip/http’ or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo’s -H flag.
WARNING: The directory ‘/home/user/.cache/pip’ or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo’s -H flag.
Looking in indexes: Simple index, https://developer.download.nvidia.com/compute/redist/jp/v42
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘SSLError(SSLError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:852)’),)’: /compute/redist/jp/v42/tensorflow-gpu/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘SSLError(SSLError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:852)’),)’: /compute/redist/jp/v42/tensorflow-gpu/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘SSLError(SSLError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:852)’),)’: /compute/redist/jp/v42/tensorflow-gpu/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘SSLError(SSLError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:852)’),)’: /compute/redist/jp/v42/tensorflow-gpu/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘SSLError(SSLError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:852)’),)’: /compute/redist/jp/v42/tensorflow-gpu/
Could not fetch URL https://developer.download.nvidia.com/compute/redist/jp/v42/tensorflow-gpu/: There was a problem confirming the ssl certificate: HTTPSConnectionPool(host=‘developer.download.nvidia.com’, port=443): Max retries exceeded with url: /compute/redist/jp/v42/tensorflow-gpu/ (Caused by SSLError(SSLError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:852)’),)) - skipping
ERROR: Could not find a version that satisfies the requirement tensorflow-gpu==1.13.1+nv19.3 (from versions: none)
ERROR: No matching distribution found for tensorflow-gpu==1.13.1+nv19.3
Could not fetch URL https://developer.download.nvidia.com/compute/redist/jp/v42/pip/: There was a problem confirming the ssl certificate: HTTPSConnectionPool(host=‘developer.download.nvidia.com’, port=443): Max retries exceeded with url: /compute/redist/jp/v42/pip/ (Caused by SSLError(SSLError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:852)’),)) - skippin
