hi,
I’m using Xavier NX with jetpack 5.1 and
I was trying to clone and use “torch2trt” for real-time pose estimation on NVIDIA Jetson from link: “GitHub - NVIDIA-AI-IOT/trt_pose: Real-time pose estimation accelerated with NVIDIA TensorRT ”.
But I got an error says which says
Traceback (most recent call last): File "setup.py", line 2, in <module> import torchImportError: No module named torch
But I have install torch and torchvision by following the nvidia forum “PyTorch for Jetson (forum 72048 )”
Could you check if you can import torch with python3 directly?
$ python3
# import torch
yeah it shows
import torch
print(torch.__version__)
print(torch.cuda.is_available())
import torchvision
print(torchvision.__version__)
also i have check there version and cuda enabled or not !
Do you meet this error when running “sudo python3 setup.py install --plugins”?
yups…,but didn’t get error if I use Jetpack 4.6
Could you check where the PyTorch is installed?
Torch2TRT is expected PyTorch is installed in /usr/local/lib/python3.8/dist-packages/torch.
But in some cases, it might be installed under $/home/.local/.
kayccc
September 12, 2023, 8:06am
10
Is this still an issue to support? Any result can be shared? Thanks
i found torch on /home/nvidia/.local/lib/python3.8/site-packages
but when i run setup.py file it unable to find torch.
also when i normally use it other code, it runs properly
Does this mean the issue is fixed?
yes…I have resolved this issue
