Hi Nvidia team,
I built torch2trt from the source (GitHub - NVIDIA-AI-IOT/torch2trt: An easy to use PyTorch to TensorRT converter). I can import it under the build folder, but I can’t import it outside that folder, why is that?
Thanks a lot!
As shown in the image, it can be seen by pip list when under the bulid folder
Could you export the PYTHONPATH with the absolute path and try it again?
