In file included from nvdsparsebbox_ssd.cpp:15:0:
…/…/includes/nvdsinfer_custom_impl.h:87:27: fatal error: NvCaffeParser.h: No such file or directory
compilation terminated.
nvdsiplugin_ssd.cpp:12:27: fatal error: NvInferPlugin.h: No such file or directory
CUDA_VER:=10.0
CC:= g++
CFLAGS:= -Wall -Werror -std=c++11 -shared -fPIC
CFLAGS+= -I…/…/includes -I/usr/local/cuda-$(CUDA_VER)/include
LIBS:= -lnvinfer -lnvparsers -L/home/nvidia/Downloads/TensorRT-5.0.2.6/
I have added the tensorRT path in the makefile, Not sure where things are going wrong
The error comes from the missing header.
Please add the TensorRT path into the include parameter.
And the path should be end in …/lib or …/inlcude.
For example
CUDA_VER:=10.0
CC:= g++
CFLAGS+= -I../../includes -I/usr/local/cuda-$(CUDA_VER)/include <b>-I/home/nvidia/TensorRT-5.1.3.6/include</b>
LIBS:= -lnvinfer -lnvparsers -L/usr/local/cuda-$(CUDA_VER)/lib64 -lcudart -lcublas <b>-L/home/nvidia/TensorRT-5.1.3.6/lib</b>
LFLAGS:= -Wl,--start-group $(LIBS) -Wl,--end-group
SRCFILES:= nvdsparsebbox_ssd.cpp nvdsiplugin_ssd.cpp
TARGET_LIB:= libnvdsinfer_custom_impl_ssd.so
all: $(TARGET_LIB)
$(TARGET_LIB) : $(SRCFILES)
$(CC) -o $@ $^ $(CFLAGS) $(LFLAGS)
clean:
rm -rf $(TARGET_LIB)
CUDA_VER:=10.0
CC:= g++
CFLAGS+= -I…/…/includes -I/usr/local/cuda-$(CUDA_VER)/include -I/home/nvidia/TensorRT-5.0.2.6/include
LIBS:= -lnvinfer -lnvparsers -L/usr/local/cuda-$(CUDA_VER)/lib64 -lcudart -lcublas -L/home/nvidia/TensorRT-5.0.2.6/lib
Added still getting the same error. I had to run make command from
/DeepStream_Release/sources/objectDetector_SSD$ make -C nvdsinfer_custom_impl_ssd
make: Entering directory ‘/home/nvidia/DeepStream_Release/sources/objectDetector_SSD/nvdsinfer_custom_impl_ssd’
g++ -o libnvdsinfer_custom_impl_ssd.so nvdsparsebbox_ssd.cpp nvdsiplugin_ssd.cpp -Wall -Werror -std=c++11 -shared -fPIC -I…/…/includes -I/usr/local/cuda-10.0/include -I/home/nvidia/TensorRT-5.0.2.6/include -Wl,–start-group -lnvinfer -lnvparsers -L/usr/local/cuda-10.0/lib64 -lcudart -lcublas -L/home/nvidia/TensorRT-5.0.2.6/lib -Wl,–end-group
Makefile:29: recipe for target ‘libnvdsinfer_custom_impl_ssd.so’ failed
make: *** [libnvdsinfer_custom_impl_ssd.so] Error 1
make: Leaving directory ‘/home/nvidia/DeepStream_Release/sources/objectDetector_SSD/nvdsinfer_custom_impl_ssd’
Am I making any mistake in running. It should be run from here right???
