Deepstream container can't make
• Hardware Platform (Jetson / GPU) 1050Ti
• DeepStream Version deepstream-5.1
• TensorRT Version 7.2.2.3
• NVIDIA GPU Driver Version (valid for GPU only) 465.27
• Issue Type( questions, new requirements, bugs) bugs
  1. pull docker using
docker pull nvcr.io/nvidia/deepstream:5.1-21.02-samples
  1. run objectDetector_Yolo in container
cd /opt/nvidia/deepstream/deepstream-5.1/sources/objectDetector_Yolo/nvdsinfer_custom_imp
l_Yolo
make CUDA_VER=11.1
get error like below
g++ -c -o nvdsinfer_yolo_engine.o -Wall -std=c++11 -shared -fPIC -Wno-error=deprecated-declarations -I…/…/includes -I/usr/local/cuda-11.1/include nvdsinfer_yolo_engine.cpp
In file included from nvdsinfer_yolo_engine.cpp:23:0:
…/…/includes/nvdsinfer_custom_impl.h:128:10: fatal error: NvCaffeParser.h: No such file or directory
#include “NvCaffeParser.h”
compilation terminated.
Makefile:51: recipe for target ‘nvdsinfer_yolo_engine.o’ failed
make: *** [nvdsinfer_yolo_engine.o] Error 1
Hi @wanty7788 ,
sample docker is just used to run some samples, it does not support to compile the sample
could you use nvcr.io/nvidia/deepstream:5.1-21.02-devel ?
