• Hardware Platform (Jetson / GPU) Jetson Orin AGX
• DeepStream Version None
• JetPack Version (valid for Jetson only) 5.1.1
• Issue Type( questions, new requirements, bugs) BUG
**• How to reproduce the issue ?
Build docker from dockerfile:
FROM nvcr.io/nvidia/deepstream:7.0-triton-multiarch
RUN apt install -y tensorrt
RUN cd /opt/nvidia/deepstream/deepstream/sources && \
git clone https://github.com/marcoslucianops/DeepStream-Yolo.git && \
cd DeepStream-Yolo/nvdsinfer_custom_impl_Yolo && \
export CUDA_VER=$(ls /usr/local | grep cuda- | tail -n 1| sed 's/cuda-//g') && \
echo "🟢 Found CUDA version: $CUDA_VER (dir /usr/local/`ls /usr/local | grep cuda- | tail -n 1`)" && \
make
You will get error:
Cloning into 'DeepStream-Yolo'...
🟢 Found CUDA version: 12.2 (dir /usr/local/cuda-12.2)
g++ -c -o nvdsinfer_yolo_engine.o -Wall -std=c++11 -shared -fPIC -Wno-error=deprecated-declarations -I/opt/nvidia/deepstream/deepstream/sources/includes -I/usr/local/cuda-12.2/include nvdsinfer_yolo_engine.cpp
In file included from nvdsinfer_yolo_engine.cpp:28:
/opt/nvidia/deepstream/deepstream/sources/includes/nvdsinfer_custom_impl.h:127:10: fatal error: NvCaffeParser.h: No such file or directory
127 | #include "NvCaffeParser.h"
compilation terminated.
make: *** [Makefile:81: nvdsinfer_yolo_engine.o] Error 1
But dockerfile:
make
Builds without any problem
