Error while training action_recognition_net with TAO
• Hardware (T4/V100/Xavier/Nano/etc)
V100
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc)
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
format_version: 2.0
toolkit_version: 3.22.05
published_date: 05/25/2022
• Training spec file(If have, please share here)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
I confirmed that the result folder($RESULTS_DIR/rgb_3d_ptm) does not exist,But when i execute the training cell i get the following error:
The same is true for 2D models
Any idea?Thanks.
Can you use below command to check if the training and val dataset are available?
! tao action_recognition run ls $DATA_DIR/train
! tao action_recognition run ls $DATA_DIR/test
The result is as follows
So, the “accident” folder is your training data or test data, right?
Yes, but I don’t understand what effect the dataset has on whether the result directory exists or not.
The result folder can be generated when run training.
It should not be related to error.
Can you follow the default notebook and double check?
I use the default notebook from cv_sample_v1.4.1 and still have the same problem.
Can you share the full log again?
Train RGB only model with PTM
2022-09-21 10:28:59,922 [INFO] root: Registry: ['nvcr.io']
2022-09-21 10:29:00,136 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit-pyt:v3.22.05-py3
2022-09-21 10:29:00,737 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the "user":"UID:GID" in the
DockerOptions portion of the "/root/.tao_mounts.json" file. You can obtain your
users UID and GID by using the "id -u" and "id -g" commands on the
terminal.
/home/jenkins/agent/workspace/tlt-pytorch-main-nightly/cv/action_recognition/scripts/train.py:76: UserWarning:
'train_rgb_3d_finetune.yaml' is validated against ConfigStore schema with the same name.
This behavior is deprecated in Hydra 1.1 and will be removed in Hydra 1.2.
See https://hydra.cc/docs/next/upgrades/1.0_to_1.1/automatic_schema_matching for migration instructions.
loading trained weights from /results/pretrained/actionrecognitionnet_vtrainable_v1.0/resnet18_3d_rgb_hmdb5_32.tlt
ResNet3d(
  (conv1): Conv3d(3, 64, kernel_size=(5, 7, 7), stride=(2, 2, 2), padding=(2, 3, 3), bias=False)
  (bn1): BatchNorm3d(64, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
  (relu): ReLU(inplace=True)
  (maxpool): MaxPool3d(kernel_size=(1, 3, 3), stride=2, padding=(0, 1, 1), dilation=1, ceil_mode=False)
  (layer1): Sequential(
    (0): BasicBlock3d(
      (conv1): Conv3d(64, 64, kernel_size=(3, 3, 3), stride=(1, 1, 1), padding=(1, 1, 1), bias=False)
      (conv2): Conv3d(64, 64, kernel_size=(3, 3, 3), stride=(1, 1, 1), padding=(1, 1, 1), bias=False)
      (bn2): BatchNorm3d(64, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
    (1): BasicBlock3d(
  (layer2): Sequential(
    (0): BasicBlock3d(
      (conv1): Conv3d(64, 128, kernel_size=(3, 3, 3), stride=(1, 2, 2), padding=(1, 1, 1), bias=False)
      (bn1): BatchNorm3d(128, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
      (conv2): Conv3d(128, 128, kernel_size=(3, 3, 3), stride=(1, 1, 1), padding=(1, 1, 1), bias=False)
      (bn2): BatchNorm3d(128, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
      (downsample): Sequential(
        (0): Conv3d(64, 128, kernel_size=(1, 1, 1), stride=(1, 2, 2), bias=False)
        (1): BatchNorm3d(128, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
    (1): BasicBlock3d(
      (conv1): Conv3d(128, 128, kernel_size=(3, 3, 3), stride=(1, 1, 1), padding=(1, 1, 1), bias=False)
  (layer3): Sequential(
    (0): BasicBlock3d(
      (conv1): Conv3d(128, 256, kernel_size=(3, 3, 3), stride=(1, 2, 2), padding=(1, 1, 1), bias=False)
      (bn1): BatchNorm3d(256, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
      (conv2): Conv3d(256, 256, kernel_size=(3, 3, 3), stride=(1, 1, 1), padding=(1, 1, 1), bias=False)
      (bn2): BatchNorm3d(256, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
        (0): Conv3d(128, 256, kernel_size=(1, 1, 1), stride=(1, 2, 2), bias=False)
        (1): BatchNorm3d(256, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
    (1): BasicBlock3d(
      (conv1): Conv3d(256, 256, kernel_size=(3, 3, 3), stride=(1, 1, 1), padding=(1, 1, 1), bias=False)
  (layer4): Sequential(
    (0): BasicBlock3d(
      (conv1): Conv3d(256, 512, kernel_size=(3, 3, 3), stride=(1, 2, 2), padding=(1, 1, 1), bias=False)
      (bn1): BatchNorm3d(512, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
      (conv2): Conv3d(512, 512, kernel_size=(3, 3, 3), stride=(1, 1, 1), padding=(1, 1, 1), bias=False)
      (bn2): BatchNorm3d(512, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
        (0): Conv3d(256, 512, kernel_size=(1, 1, 1), stride=(1, 2, 2), bias=False)
        (1): BatchNorm3d(512, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
    (1): BasicBlock3d(
      (conv1): Conv3d(512, 512, kernel_size=(3, 3, 3), stride=(1, 1, 1), padding=(1, 1, 1), bias=False)
  (avg_pool): AdaptiveAvgPool3d(output_size=(1, 1, 1))
  (fc_cls): Linear(in_features=512, out_features=3, bias=True)
/opt/conda/lib/python3.8/site-packages/pytorch_lightning/trainer/connectors/callback_connector.py:147: LightningDeprecationWarning: Setting `Trainer(checkpoint_callback=False)` is deprecated in v1.5 and will be removed in v1.7. Please consider using `Trainer(enable_checkpointing=False)`.
  rank_zero_deprecation(
GPU available: True, used: True
TPU available: False, using: 0 TPU cores
IPU available: False, using: 0 IPUs
Train dataset samples: 26
Validation dataset samples: 2
LOCAL_RANK: 0 - CUDA_VISIBLE_DEVICES: [0,1,2,3,4,5,6,7]
Adjusting learning rate of group 0 to 3.0000e-04.
  | Name           | Type     | Params
0 | model          | ResNet3d | 33.2 M
1 | train_accuracy | Accuracy | 0
2 | val_accuracy   | Accuracy | 0
33.2 M    Trainable params
0         Non-trainable params
33.2 M    Total params
132.747   Total estimated model params size (MB)
/opt/conda/lib/python3.8/site-packages/pytorch_lightning/callbacks/model_checkpoint.py:623: UserWarning: Checkpoint directory /results/rgb_3d_ptm exists and is not empty.
  rank_zero_warn(f"Checkpoint directory {dirpath} exists and is not empty.")
Validation sanity check:   0%|                            | 0/1 [00:00<?, ?it/s]Error executing job with overrides: ['output_dir=/results/rgb_3d_ptm', 'encryption_key=nvidia_tao', 'model_config.rgb_pretrained_model_path=/results/pretrained/actionrecognitionnet_vtrainable_v1.0/resnet18_3d_rgb_hmdb5_32.tlt', 'model_config.rgb_pretrained_num_classes=5']
  File "/opt/conda/lib/python3.8/site-packages/hydra/_internal/utils.py", line 211, in run_and_report
    return func()
  File "/opt/conda/lib/python3.8/site-packages/hydra/_internal/utils.py", line 368, in <lambda>
    lambda: hydra.run(
  File "/opt/conda/lib/python3.8/site-packages/hydra/_internal/hydra.py", line 110, in run
    _ = ret.return_value
  File "/opt/conda/lib/python3.8/site-packages/hydra/core/utils.py", line 233, in return_value
    raise self._return_value
  File "/opt/conda/lib/python3.8/site-packages/hydra/core/utils.py", line 160, in run_job
    ret.return_value = task_function(task_cfg)
  File "/home/jenkins/agent/workspace/tlt-pytorch-main-nightly/cv/action_recognition/scripts/train.py", line 70, in main
  File "/home/jenkins/agent/workspace/tlt-pytorch-main-nightly/cv/action_recognition/scripts/train.py", line 59, in run_experiment
  File "/opt/conda/lib/python3.8/site-packages/pytorch_lightning/trainer/trainer.py", line 737, in fit
    self._call_and_handle_interrupt(
  File "/opt/conda/lib/python3.8/site-packages/pytorch_lightning/trainer/trainer.py", line 682, in _call_and_handle_interrupt
    return trainer_fn(*args, **kwargs)
  File "/opt/conda/lib/python3.8/site-packages/pytorch_lightning/trainer/trainer.py", line 772, in _fit_impl
    self._run(model, ckpt_path=ckpt_path)
  File "/opt/conda/lib/python3.8/site-packages/pytorch_lightning/trainer/trainer.py", line 1195, in _run
    self._dispatch()
  File "/opt/conda/lib/python3.8/site-packages/pytorch_lightning/trainer/trainer.py", line 1274, in _dispatch
    self.training_type_plugin.start_training(self)
  File "/opt/conda/lib/python3.8/site-packages/pytorch_lightning/plugins/training_type/training_type_plugin.py", line 202, in start_training
    self._results = trainer.run_stage()
  File "/opt/conda/lib/python3.8/site-packages/pytorch_lightning/trainer/trainer.py", line 1284, in run_stage
    return self._run_train()
  File "/opt/conda/lib/python3.8/site-packages/pytorch_lightning/trainer/trainer.py", line 1306, in _run_train
    self._run_sanity_check(self.lightning_module)
  File "/opt/conda/lib/python3.8/site-packages/pytorch_lightning/trainer/trainer.py", line 1370, in _run_sanity_check
    self._evaluation_loop.run()
  File "/opt/conda/lib/python3.8/site-packages/pytorch_lightning/loops/base.py", line 145, in run
    self.advance(*args, **kwargs)
  File "/opt/conda/lib/python3.8/site-packages/pytorch_lightning/loops/dataloader/evaluation_loop.py", line 109, in advance
    dl_outputs = self.epoch_loop.run(dataloader, dataloader_idx, dl_max_batches, self.num_dataloaders)
  File "/opt/conda/lib/python3.8/site-packages/pytorch_lightning/loops/base.py", line 140, in run
    self.on_run_start(*args, **kwargs)
  File "/opt/conda/lib/python3.8/site-packages/pytorch_lightning/loops/epoch/evaluation_epoch_loop.py", line 86, in on_run_start
    self._dataloader_iter = _update_dataloader_iter(data_fetcher, self.batch_progress.current.ready)
  File "/opt/conda/lib/python3.8/site-packages/pytorch_lightning/loops/utilities.py", line 121, in _update_dataloader_iter
    dataloader_iter = enumerate(data_fetcher, batch_idx)
  File "/opt/conda/lib/python3.8/site-packages/pytorch_lightning/utilities/fetching.py", line 199, in __iter__
    self.prefetching(self.prefetch_batches)
  File "/opt/conda/lib/python3.8/site-packages/pytorch_lightning/utilities/fetching.py", line 258, in prefetching
    self._fetch_next_batch()
  File "/opt/conda/lib/python3.8/site-packages/pytorch_lightning/utilities/fetching.py", line 300, in _fetch_next_batch
    batch = next(self.dataloader_iter)
  File "/opt/conda/lib/python3.8/site-packages/torch/utils/data/dataloader.py", line 521, in __next__
    data = self._next_data()
  File "/opt/conda/lib/python3.8/site-packages/torch/utils/data/dataloader.py", line 1203, in _next_data
    return self._process_data(data)
  File "/opt/conda/lib/python3.8/site-packages/torch/utils/data/dataloader.py", line 1229, in _process_data
    data.reraise()
  File "/opt/conda/lib/python3.8/site-packages/torch/_utils.py", line 438, in reraise
    raise exception
omegaconf.errors.ConfigKeyError: Caught ConfigKeyError in DataLoader worker process 0.
Original Traceback (most recent call last):
  File "/opt/conda/lib/python3.8/site-packages/torch/utils/data/_utils/worker.py", line 287, in _worker_loop
    data = fetcher.fetch(index)
  File "/opt/conda/lib/python3.8/site-packages/torch/utils/data/_utils/fetch.py", line 49, in fetch
    data = [self.dataset[idx] for idx in possibly_batched_index]
  File "/opt/conda/lib/python3.8/site-packages/torch/utils/data/_utils/fetch.py", line 49, in <listcomp>
  File "/home/jenkins/agent/workspace/tlt-pytorch-main-nightly/cv/action_recognition/dataloader/ar_dataset.py", line 239, in __getitem__
  File "/home/jenkins/agent/workspace/tlt-pytorch-main-nightly/cv/action_recognition/dataloader/ar_dataset.py", line 195, in get_frames
  File "/opt/conda/lib/python3.8/site-packages/omegaconf/dictconfig.py", line 369, in __getitem__
    self._format_and_raise(
  File "/opt/conda/lib/python3.8/site-packages/omegaconf/base.py", line 190, in _format_and_raise
    format_and_raise(
  File "/opt/conda/lib/python3.8/site-packages/omegaconf/_utils.py", line 741, in format_and_raise
    _raise(ex, cause)
  File "/opt/conda/lib/python3.8/site-packages/omegaconf/_utils.py", line 719, in _raise
    raise ex.with_traceback(sys.exc_info()[2])  # set end OC_CAUSE=1 for full backtrace
  File "/opt/conda/lib/python3.8/site-packages/omegaconf/dictconfig.py", line 367, in __getitem__
    return self._get_impl(key=key, default_value=_DEFAULT_MARKER_)
  File "/opt/conda/lib/python3.8/site-packages/omegaconf/dictconfig.py", line 438, in _get_impl
    node = self._get_node(key=key, throw_on_missing_key=True)
  File "/opt/conda/lib/python3.8/site-packages/omegaconf/dictconfig.py", line 465, in _get_node
    self._validate_get(key)
  File "/opt/conda/lib/python3.8/site-packages/omegaconf/dictconfig.py", line 166, in _validate_get
    format_and_raise(
  File "/opt/conda/lib/python3.8/site-packages/omegaconf/_utils.py", line 821, in format_and_raise
    _raise(ex, cause)
omegaconf.errors.ConfigKeyError: Key 'accident' is not in struct
    full_key: dataset_config.label_map.accident
    reference_type=Optional[Dict[str, int]]
    object_type=dict
During handling of the above exception, another exception occurred:
  File "/home/jenkins/agent/workspace/tlt-pytorch-main-nightly/cv/action_recognition/scripts/train.py", line 76, in <module>
  File "/home/jenkins/agent/workspace/tlt-pytorch-main-nightly/cv/super_resolution/scripts/configs/hydra_runner.py", line 99, in wrapper
  File "/opt/conda/lib/python3.8/site-packages/hydra/_internal/utils.py", line 367, in _run_hydra
    run_and_report(
  File "/opt/conda/lib/python3.8/site-packages/hydra/_internal/utils.py", line 251, in run_and_report
    assert mdl is not None
AssertionError
2022-09-21 10:29:33,753 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
On run it automatically creates $RESULTS_DIR/rgb_3d_ptm and throws the error.
Above error provides the hint that there is something wrong in the dataset structure.
Could you follow default notebook and use the dataset mentioned in the notebook and try again?
More info can be found in ActionRecognitionNet — TAO Toolkit 3.22.05 documentation
I follow default notebook and use the dataset mentioned in the notebook still getting the same error
2022-09-21 11:27:32,925 [INFO] root: Registry: ['nvcr.io']
2022-09-21 11:27:33,120 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit-pyt:v3.22.05-py3
2022-09-21 11:27:33,672 [WARNING] tlt.components.docker_handler.docker_handler:
terminal.
ResNet3d(
    (0): BasicBlock3d(
    (1): BasicBlock3d(
    (0): BasicBlock3d(
    (1): BasicBlock3d(
    (0): BasicBlock3d(
    (1): BasicBlock3d(
    (0): BasicBlock3d(
    (1): BasicBlock3d(
Train dataset samples: 140
Validation dataset samples: 60
33.2 M    Total params
Validation sanity check:   0%|                            | 0/2 [00:00<?, ?it/s]Error executing job with overrides: ['output_dir=/results/rgb_3d_ptm', 'encryption_key=nvidia_tao', 'model_config.rgb_pretrained_model_path=/results/pretrained/actionrecognitionnet_vtrainable_v1.0/resnet18_3d_rgb_hmdb5_32.tlt', 'model_config.rgb_pretrained_num_classes=5']
    return func()
    lambda: hydra.run(
    self._dispatch()
    data.reraise()
    raise exception
    format_and_raise(
    _raise(ex, cause)
    format_and_raise(
    _raise(ex, cause)
omegaconf.errors.ConfigKeyError: Key 'fall_floor' is not in struct
    full_key: dataset_config.label_map.fall_floor
    object_type=dict
    run_and_report(
AssertionError
2022-09-21 11:28:04,905 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
Can you share the yaml file? Did you use the default yaml file?
Still getting that error, but it works
Which error did you mean?
I get it, the cause of the problem is not that the folder already exists
Yes, the reason may be the label_map setting.
