Hi, I used the tlt_instance_segmentation docker with the notebook to train a model on my custom dataset containing only 1 class ( 2 with background ). Everything works fine up until I try to infer on my test set:
# Running inference for detection on n images
!tlt-infer mask_rcnn -i $RAW_DATA_DIR/images/test \
-o $USER_EXPERIMENT_DIR/maskrcnn_annotated_images \
-e $SPECS_DIR/maskrcnn_train_resnet50.txt \
-m $USER_EXPERIMENT_DIR/experiment_dir_unpruned/model.step-25000.tlt \
-l $SPECS_DIR/coco_labels.txt \
-t 0.5 \
-b 2 \
-k $KEY \
--include_mask
I get this error:
Using TensorFlow backend.
2021-01-15 16:57:52.117876: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
File "/usr/local/bin/tlt-infer", line 8, in <module>
sys.exit(main())
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/magnet_infer.py", line 60, in main
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/inference.py", line 288, in main
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/inference.py", line 230, in infer
AssertionError: Batch size should not be greater than the number of samples.
Any clues?
Obviously, the folder does contain more than 2 images. The same error is also thrown with a batch of 1.
