I have gone through the process of training a Segmentation model - MaskRCNN using the coco-2017 data-set in TLT-3.0, and trained the model with the default configuration provided in NVIDIA TLT-3.0. I get errors deploying the model trained using the default data-set.
Now i am trying to make a custom Segmentation model created from custom data-set.
I have annotated the data using the Intel CVAT and exported it into TFrecord which is used to feed into the config file for the training process.
My Questions :
Is there any constrains that i have to deal with before changing the training steps parameter ?
Can it take both JPEG and PNG as data-set formats ?
How to deploy the model into deepstream or what is the application format that is for Segmentation,
Is it the deepstream-mrcnn-app or the deepstream-segmentation-test ?
Is it mandatory for the data-set to have a BG (BackGround) class for an both scemantic & instance segmentation model ?
After a Successful model generation using Default/Custom Data-set and trying to deploy the model under Deepstream with the config file similar to shown here https://developer.nvidia.com/blog/training-instance-segmentation-models-using-maskrcnn-on-the-transfer-learning-toolkit/, I end up getting errors such as
a) While trying to run the model using the deepstream-segmentation-test application
0:00:00.298115171 563 0x561db309c630 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 1]: Trying to create engine from model files
ERROR: …/nvdsinfer/nvdsinfer_func_utils.cpp:33 [TRT]: UffParser: Validator error: generate_detections: Unsupported operation _GenerateDetection_TRT
parseModel: Failed to parse UFF model
ERROR: tlt/tlt_decode.cpp:274 failed to build network since parsing model errors.
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:797 Failed to create network using custom network creation function
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:862 Failed to get cuda engine from custom library API
0:00:00.691056241 563 0x561db309c630 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1735> [UID = 1]: build engine file failed
b) While trying to run the model using the deepstream-app as shown in the
Quitting
ERROR from src_bin_muxer: Output width not set
Debug info: gstnvstreammux.c(2283): gst_nvstreammux_change_state (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstNvStreamMux:src_bin_muxer
App run failed
Note :
The Errors where same for both models with the provided default dataset and an custom dataset. While training ,the process didn’t get any errors, the custom dataset is a single class dataset.
