I follow this guide for yolov7 qat https://github.com/NVIDIA-AI-IOT/yolo_deepstream/tree/main/yolov7_qat
In this repo BN layer in fused into Conv layer before ptq. Now I don’t want to fuse BN layer into Conv layers. I comment out 2 lines https://github.com/NVIDIA-AI-IOT/yolo_deepstream/blob/5af35bab7f6dfca7f1f32d44847b2a91786485f4/yolov7_qat/scripts/qat.py#L79 but when running I got an error
File "scripts/qat_BN.py", line 338, in <module>
cmd_quantize(
File "scripts/qat_BN.py", line 179, in cmd_quantize
quantize.apply_custom_rules_to_quantizer(model, export_onnx)
File "/yolov7_custom_dataset/quantization/quantize.py", line 222, in apply_custom_rules_to_quantizer
export_onnx(model, "quantization-custom-rules-temp.onnx")
File "scripts/qat_BN.py", line 138, in export_onnx
quantize.export_onnx(model, dummy, file, opset_version=13,
File "/yolov7_custom_dataset/quantization/quantize.py", line 394, in export_onnx
torch.onnx.export(model, input, file, *args, **kwargs)
File "/usr/local/lib/python3.8/dist-packages/torch/onnx/utils.py", line 506, in export
_export(
File "/usr/local/lib/python3.8/dist-packages/torch/onnx/utils.py", line 1548, in _export
graph, params_dict, torch_out = _model_to_graph(
File "/usr/local/lib/python3.8/dist-packages/torch/onnx/utils.py", line 1180, in _model_to_graph
params_dict = _C._jit_pass_onnx_constant_fold(
RuntimeError: Expected all tensors to be on the same device, but found at least two devices, cuda:0 and cpu! (when checking argument for argument index in method wrapper_CUDA__index_select)
Do you any have suggesstion for me? this was happen when convert to onnx
