Error with ROS2 Humble and Isaac SIM 4.0: rclpy failed to be imported while being present on the system
Hi, I am having some problems in running Isaac SIM 4.0 with ROS2.
I added in an empty scene the ROS2 clock setup from isaac utils tab and when I run ros2 topic list or any ros command I get an error saying that the C extension rclpy failed to be imported while being present on the system.
Here is the complete error:
  File "/opt/ros/humble/bin/ros2", line 33, in <module>
    sys.exit(load_entry_point('ros2cli==0.18.11', 'console_scripts', 'ros2')())
  File "/opt/ros/humble/bin/ros2", line 25, in importlib_load_entry_point
    return next(matches).load()
  File "/usr/lib/python3.10/importlib/metadata/__init__.py", line 171, in load
    module = import_module(match.group('module'))
  File "/usr/lib/python3.10/importlib/__init__.py", line 126, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1050, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
  File "<frozen importlib._bootstrap>", line 1006, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 688, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 883, in exec_module
  File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
  File "/opt/ros/humble/lib/python3.10/site-packages/ros2cli/cli.py", line 22, in <module>
    from rclpy.executors import ExternalShutdownException
  File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/__init__.py", line 49, in <module>
    from rclpy.signals import install_signal_handlers
  File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/signals.py", line 15, in <module>
    from rclpy.exceptions import InvalidHandle
  File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/exceptions.py", line 15, in <module>
    from rclpy.impl.implementation_singleton import rclpy_implementation as _rclpy
  File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/impl/implementation_singleton.py", line 32, in <module>
    rclpy_implementation = import_c_library('._rclpy_pybind11', package)
  File "/opt/ros/humble/lib/python3.10/site-packages/rpyutils/import_c_library.py", line 39, in import_c_library
    return importlib.import_module(name, package=package)
ImportError: /opt/ros/humble/lib/librcl_logging_spdlog.so: undefined symbol: _ZN6spdlog7details7log_msgC1ENS_10source_locEN3fmt2v817basic_string_viewIcEENS_5level10level_enumES6_
The C extension '/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/_rclpy_pybind11.cpython-310-x86_64-linux-gnu.so' failed to be imported while being present on the system. Please refer to 'https://docs.ros.org/en/{distro}/Guides/Installation-Troubleshooting.html#import-failing-even-with-library-present-on-the-system' for possible solutions
after the error, ROS2 on my system resume working only after a reboot.
Using Isaac SIM 2023.1.1 on the same machine I have no issues and everything works
How can I solve this problem?
It might be helpful to test ROS 2 commands without launching Isaac Sim to isolate whether the problem is with ROS 2 itself or its interaction with Isaac Sim. If the issue occurs even without Isaac Sim running, it’s likely a ROS 2 configuration problem that needs to be addressed first.
Hi, thank you for answering! i am fairly sure that the problem is not of ROS2 itself as it started appearing only after I launched IsaacSim 4.0.
ROS2 has been used without issues without Isaac Sim and using IsaacSim 2023.1.1
I did some tests and I discovered that the issue arise when changing the DDS after having started Isaac Sim with another DDS implementation.
Minimal set of steps to reproduce:
  • With fastDDS enabled (RMW_IMPLEMENTATION environment variable set) start Isaac Sim 4.0 with the ros2 extension.
  • After Isaac Sim opened close it without opening a project or anything.
  • Set the RMW_IMPLEMENTATION to rmw_cyclonedds_cpp in the bashrc file
  • Start again Isaac Sim 4.0
  • Doing ros2 topic list on a freshly opened terminal trigger the error.
By removing the Isaac Sim steps in the previous list ROS2 still works without errors.
Anyway, there is a way to restore the system to a working state when the problem starts appearing? I have found that restarting the system is the only solution, I also tried ros2 daemon stop/start and changing again the DDS to Cyclone but it didn’t worked.
UPDATE: the issue also appeared after the first isaac startup after a system boot. So it is not fully defined when it happens.
I’m having the same issue when i’m trying to install and run ROS2 on an Isaac Sim container (seemingly any version of Isaac Sim | NVIDIA NGC)
@parmeggiani.alessio Did you manage to find the cause of this issue?
Nope, I haven’t found a solution, at the moment I am using Isaac Sim 2023.1.1 that doesn’t have this issue.
I am not using containers, it is a native installation
I stumbled across this issue recently. It seems that there can be a conflict between the ROS libraries packaged with IsaacSim and ROS libraries that you install directly onto your system i.e. using apt.
The simple fix for me was by clearing the LD_LIBRARY_PATH environment variable, which in my case, was set to the IsaacSim lib folder. You should only clear this variable in the terminal you want to run the ROS commands in:
printenv LD_LIBRARY_PATH    # Check if this points to IsaacSim libraries
unset LD_LIBRARY_PATH
LD_LIBRARY_PATH should be specified in the terminal used to launch IsaacSim.
Thanks to @daniel.mooney180 for finding the fix – wanted to confirm the root cause and summarize for anyone who lands here.
Root cause: LD_LIBRARY_PATH pollution from Isaac Sim’s shell scripts
When you run isaac-sim.sh (or python.sh) in a terminal, they export LD_LIBRARY_PATH to include Isaac Sim’s bundled libraries. That export persists in the same shell after Isaac Sim exits. The next ros2 command in that terminal picks up Isaac Sim’s bundled libspdlog instead of the system one – and they are ABI-incompatible.
The specific error confirms this:
ROS Humble’s librcl_logging_spdlog.so was built against fmt v8. Isaac Sim ships its own libspdlog built against different fmt versions – so the symbol is missing, and ROS breaks.
This also explains the DDS-switching trigger in post #3: relaunching Isaac Sim in the same terminal appended to an already-contaminated LD_LIBRARY_PATH, and the problem became persistent until reboot (which starts a fresh shell with a clean environment).
Fix
Use a dedicated terminal for Isaac Sim – never run ros2 commands in the same terminal where you launched Isaac Sim:
# Terminal 1: Isaac Sim only
cd /path/to/isaacsim && ./isaac-sim.sh
# Terminal 2: ROS commands only -- do NOT run isaac-sim.sh here
ros2 topic list
If a terminal is already contaminated, clear the variable before running ROS commands:
ros2 topic list
And avoid sourcing isaac-sim.sh or python.sh in your .bashrc – only run them in dedicated launch terminals.
Marking this resolved. If the issue persists after separating your terminals, please open a new topic with your full LD_LIBRARY_PATH output and Isaac Sim version.
