This occurs when the libcuda.so is not present or your LD_LIBRAY_PATH environment variable is not defined properly. Check the /usr/local/cuda/lib for libcuda.so, if there’s no libcuda available try to install the most recent version of the nvidia drivers.
Sorry but that is incorrect. libcuda.so is installed in /usr/lib and the compiler should find it by default. If the compiler doesn’t find it, then it isn’t installed or something is broken. LD_LIBRARY_PATH settings should have no effect on this problem - /usr/lib should be searched by defaut
