Because I have no NV video card ,so I have not installed the driver
After I have installed the Toolkit and SDK successfully, I type “make emu=1 dbg=1”
But the result is :/usr/bin/ld:cannot find -lcuda, Why?
(I find there is no libcuda.so in the /usr/local/cuda/lib,
just becase I have not installed the driver?)
Some of the SDK examples are written with the driver API and have no emulation mode. These are likely the ones causing the problem. Try building just the projects you want to try in emulation mode and they should work.
Get the NVIDIA Driver for Linux with CUDA Support from NVIDIAs CUDA Zone.
Extract the .run, on terminal: $ sh ./NVIDIA-Linux-x86-177.73-pkg1.run --extract-only ./
The name of the file can change.
Copy the .so files of the driver packages to the other CUDA libraries (/usr/local/cuda/lib).
Like: $ sudo cp ./NVIDIA-Linux-x86-177.73-pkg1/lib/.* /usr/local/cuda/lib/
Add a symbolic link: cd /usr/local/cuda/lib/
’sudo ln -s libcuda.so.177.73 libcuda.so’
(In my case the lib is named “libcuda.so.177.73″. It my be different on your system.)
Go to the SDK directory and run make with emulation option enabled:
‘make emu=1′ or ‘make emu=1 dbg=1′ for debug mode
I compiled every ok. But, when I try to run anything, I get it:
error while loading shared libraries: libcudart.so.2: cannot open shared object file: No such file or directory
