I am having difficulties compiling the sdk. Specifically, when I attempt a make I get the following errors:
[codebox]make[1]: Entering directory `/home/userid/NVIDIA_CUDA_SDK/projects/histogram256’
/usr/include/bits/stdio2.h(35): error: identifier “__builtin_va_arg_pack” is undefined
/usr/include/bits/stdio2.h(66): error: identifier “__builtin_va_arg_pack” is undefined
/usr/include/bits/stdio2.h(99): error: identifier “__builtin_va_arg_pack” is undefined
/usr/include/bits/stdio2.h(105): error: identifier “__builtin_va_arg_pack” is undefined
/usr/include/bits/stdio2.h(159): error: identifier “__builtin_va_arg_pack” is undefined
/usr/include/bits/stdio2.h(167): error: identifier “__builtin_va_arg_pack” is undefined
/usr/include/bits/stdio2.h(174): error: identifier “__builtin_va_arg_pack” is undefined
/usr/include/bits/stdio2.h(182): error: identifier “__builtin_va_arg_pack” is undefined
8 errors detected in the compilation of “/tmp/tmpxft_00006092_00000000-4_histogram256_SM10.cpp1.ii”.
make[1]: *** [obj/release/histogram256_SM10.cu_sm_10.o] Error 255
make[1]: Leaving directory `/home/userid/NVIDIA_CUDA_SDK/projects/histogram256’
make: *** [projects/histogram256/Makefile.ph_build] Error 2
[/codebox]
Details of the machine:
Kubuntu 8.10 64bit
gcc (Ubuntu 4.3.2-1ubuntu12) 4.3.2
2x 8800M GT
I’ve noticed several others have had the same issue, but I have not seen a solution to this problem.
Any ideas?
[/codebox]
Kubuntu 8.10 64bit
2x 8800M GT
Any ideas?
I believe that this is a known bug in the gcc that ships with Ubuntu-8.10. As Ubuntu-8.10 isn’t currently supported, there is no current workaround that I’m aware of. It will be worked around in nvcc (and friends) in the next CUDA release, when Ubuntu-8.10 will be formally supported.
Thank you for your response. Any idea as to when support for 8.10 will arrive?
A second question, I did manage to get things compiling (after removing the -O3 flag), however when I attempt to run deviceQuery, I get the following
error:
cudaSafeCall() Runtime API error in file <deviceQuery.cu>, line 59 : invalid argument.
I know that 8.10 is not supported, however I wonder what the meaning of this error is (perhaps this error is not a result of no 8.10 support).
I made some changes to deviceQuery’s code, and was able to determine that “cudaGetDeviceProperties(&deviceProp, dev);”
returns error code 11. And when I attempt to read the device name, I get a string of 4 nonsense characters (funky question mark symbols from the
extended ascii set). However it was able to determine that I had 2 devices.
Any thoughts?
Thanks for the help!
I have found a workaround on my install of intrepid:
[codebox]$ sudo apt-get install gcc-4.2 g+±4.2
$ sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-4.2 60 --slave /usr/bin/g++ g++ /usr/bin/g+±4.2[/codebox]
This basically rolls back to using GCC 4.2.
mv1
February 12, 2009, 12:16pm
#5
I just tried compiling the SDK on a new build with RHEL 5.3 64-bit and got the following errors:
In file included from ParticleSystem.cu:42:
ParticleSystem.cuh:22:2: warning: no newline at end of file
./new_radixsort.cu(380): Advisory: Removed dead synchronization intrinsic
./new_radixsort.cu(1047): Advisory: Removed dead synchronization intrinsic
/usr/bin/ld: cannot find -lglut
collect2: ld returned 1 exit status
make[1]: *** […/…/bin/linux/release/smokeParticles] Error 1
make[1]: Leaving directory `/root/NVIDIA_CUDA_SDK/projects/smokeParticles’
make: *** [projects/smokeParticles/Makefile.ph_build] Error 2
[root@localhost NVIDIA_CUDA_SDK]#
[root@localhost NVIDIA_CUDA_SDK]# echo $LD_LIBRARY_PATH
:/usr/local/cuda/lib
[root@localhost NVIDIA_CUDA_SDK]# echo $PATH
/usr/kerberos/sbin:/usr/kerberos/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/X11R6/bin:/root/bin:/usr/local/cuda/bin
Would appreciate help to fix the above.
Thank you!
You need to install the glut libraries. You can search the forums for the exact name, I think it is called libGL-devel, but am not sure.
RHEL 5.3 is not supported btw, so you can encounter more trouble (that might be unsolvable). There are 2 options if I understand good:
install RHEL 5.2
downgrade GCC.
tmurray
February 12, 2009, 8:21pm
#7
RHEL 5.3 works fine, it’s still an older compiler:
[root@localhost /]# gcc --version
gcc (GCC) 4.1.2 20080704 (Red Hat 4.1.2-44)
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
[root@localhost /]# uname -r
2.6.18-128.el5
aka, that’s RHEL 5.3 I’m running at this very second (and I’ve got Ubuntu 8.10 on another machine! netllama probably thinks I’m a horrible person)
so not officially supported at the moment, but I’ve yet to encounter any meaningful problems
mv1
February 13, 2009, 1:33am
#8
2.6.18-128.el5
When will it be supported officially?
Hopefully very soon.
What kinds of meaningless problems have you encountered?
So, what shall I do?
Downgrade to RHEL 5.2 or go ahead with 5.3?
tmurray
February 13, 2009, 6:18am
#9
Up to you–it will be supported at Some Point (I don’t presume to speak for the driver or toolkit teams), but that will affect future releases only.
HankD
February 27, 2009, 6:45pm
#10
Going back to 4.2 isn’t necessary. This problem comes down to a little piece of
[codebox]/usr/include/sys/cdefs.h[/codebox]
that defines the builtin versions only if it’s 4.3. I simply took those defs out and
everything apparently works fine. The stuff to disable is:
[codebox]#if __GNUC_PREREQ (4,3)
define __va_arg_pack() __builtin_va_arg_pack ()
define __va_arg_pack_len() __builtin_va_arg_pack_len ()
#endif [/codebox]
Yeah, I know editing such files is bad, but it works without going back to GCC 4.2.
#endif [/codebox]
Thanks, it seems to work now. I could not solve the problem by reverting to 4.2 (I edited the example’s Makefile to use g+±4.2 and gcc-4.2 and it gave the same error), what worked was removing the optimization -03 altogether. Removing the optimizations is bad for me, as long as cdefs.h does not break anything it would work for me.
