Errors in Training, 0 or Nan mAP, Low Loss, Tutorial Config
Complete KITTI for Caltech Birds Dataset, padded.
kitti_complete_list.txt (757.1 KB)
EDIT: reuploaded complete list.
Can you share the exact address for downloading the training image?
I want to reproduce your issue on my side.
@Morganh
http://www.vision.caltech.edu/visipedia/CUB-200-2011.html
Thanks. Did you download this tar file? https://drive.google.com/file/d/1hbzc_P1FuxMkcabkgn9ZKinBwW683j45/view
That is the one I am using.
Thanks for the info.
You can try a lower batch-size. To see if it can help.
First Epoch:
(batch size 1)
Epoch 1/80
Validation cost: 0.001583
Mean average_precision (in %): 0.3687
class name average precision (in %)
bird 0.368713
Higher batch size:
Validation cost: 0.002070
Mean average_precision (in %): 0.0090
bird 0.00901658
very slow and 0 mAP, batch size 1
Epoch 21/80
Validation cost: 0.000940
Mean average_precision (in %): 0.0000
bird 0
Median Inference Time: 0.040929
2021-01-17 09:50:21,505 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 21/80: loss: 0.27364 Time taken: 0:18:25.144697 ETA: 18:06:43.537148
I can reproduce the mAP 0 . Seems that the loss does not converge.
Will trigger more experiments for find what is going wrong.
@Morganh
Thanks Morganh. Looking forward to learning what you find.
Please use below spec to train.
It runs with resnet18 backbone, bs4 and totally 120 epochs.Train_bird.txt (3.1 KB)
It can fix your issue.
When it runs at 30th epoch, the mAP is already 85%.
In the end, the training result is 92.9396%.
Epoch 120/120
Validation cost: 0.000202
Mean average_precision (in %): 92.9396
bird 92.9396
@Morganh
I started training with the spec you linked. I will post results when I have finished.
/task_progress_monitor_hook.pyc: Epoch 0/120: loss: 0.10980 Time taken: 0:00:00 ETA: 0:00:00
Final Output of Training:
Epoch 120/120
Validation cost: 0.000215
Mean average_precision (in %): 91.2699
bird 91.2699
Median Inference Time: 0.010165
@Morganh
Here is a sample Deepstream output of the Detectnet_v2 on Resnet 18:
Another sample:
