I am attempting to get an application running in a Docker container on a Jetson TX2 running jetpack 3.3. I am doing some video processing using a camera as input and am getting errors creating an encoder. I tried running the video_encode sample and get the same errors.
video_encode video.h264 640 480 H264 temp.vid
Failed to query video capabilities: Inappropriate ioctl for device
libv4l2: error getting capabilities: Inappropriate ioctl for device
[ERROR] (NvV4l2Element.cpp:63) <enc0> Could not open device '/dev/nvhost-msenc': Inappropriate ioctl for device
[ERROR] (NvV4l2ElementPlane.cpp:496) <enc0> Output Plane:Error in VIDIOC_REQBUFS at output plane: Bad file descriptor
[ERROR] (NvV4l2ElementPlane.cpp:496) <enc0> Capture Plane:Error in VIDIOC_REQBUFS at output plane: Bad file descriptor
Could not create encoder
I am mapping the /dev/nvhost-msenc device into the container, so I am not quite sure the problem is. This runs fine on my host device, just not in the container.
