Errors when using tensorRT2 to accelerate SSD(caffe)
I want to accelerate SSD by adding other plugin layers into the sampleFasterRCNN. But I meet some errors at layer ‘mbox_loc’ and ‘mbox_conf’ when I put the plugins together:
“Plugin layer output count is not equal to caffe output count”.
What does that means? And could you please send me the source code of the tensorRT2.1?
Please make sure the output blob number is equal.
  1. Plugin: int getNbOutputs()
  2. Caffe: definition of prototxt file, top: xxx
TensorRT doesn’t an opensource library. But you can find some sample code here:
Here is the code:
int getNbOutputs() const override
std::cout << “getNbOutputs” << std::endl;
return 1;
layer {
type: “IPlugin”
bottom: “conv4_3_norm_mbox_loc_flat”
bottom: “fc7_mbox_loc_flat”
bottom: “conv6_2_mbox_loc_flat”
bottom: “conv7_2_mbox_loc_flat”
bottom: “conv8_2_mbox_loc_flat”
bottom: “conv9_2_mbox_loc_flat”
top: “mbox_loc”
But there is no output string “getNbOutputs”!
Please remember to add your plugin to plugin factory:
https://github.com/AastaNV/Face-Recognition/blob/master/pluginImplement.cpp#L17
I figure it out! That is because I forget to call function mConcatPlugin.get(). So sad.
Hi @2013302477 are you able to share the source, I have been stuck with the problem of optimizing SSD with tensorRT the recent weeks.
