I am getting following errors when I try to compile my codes. I am using pgi-10.8, because I am using a cluster where this has been installed. I compiled the codes in emulation mode on my PC using pgi-10.9, but it compiles well.
[krane@honest4 ~/fourier1]$ make
pgfortran -fast -c fouriercalc1.cuf -o fouriercalc1.o
/tmp/pgcudafor4dKfOpJRBZP8.gpu(70): error: expected an identifier
/tmp/pgcudafor4dKfOpJRBZP8.gpu(72): error: expected an identifier
/tmp/pgcudafor4dKfOpJRBZP8.gpu(72): error: expected an expression
/tmp/pgcudafor4dKfOpJRBZP8.gpu(145): error: expected an expression
/tmp/pgcudafor4dKfOpJRBZP8.gpu(151): error: expected an expression
5 errors detected in the compilation of “/tmp/pgnvd2eKfI3wGGbSz.nv0”.
PGF90-F-0000-Internal compiler error. pgnvd job exited with nonzero status code 0 (fouriercal
c1.cuf: 181)
PGF90/x86-64 Linux 10.8-0: compilation aborted
make: *** [fouriercalc1.o] Error 2
Following is the file which is giving errors
! CUDA Fortran Source File
! Generated by PGI Visual Fortran(R)
! 10/21/2010 2:39:16 PM
module fouriercalc
Use ewald
Use xyz
Use sp
Use realcalc
Use cudafor
!Storing the constant arrays in constant memory of GPUs
implicit none
contains
!Starting with the Kernel subroutine
attributes(global) subroutine fourier_kernel(KX, KY, KZ, EXPX, EXPY, EXPZ, SUMQEXPV,&
EXPX_T, EXPY_T, EXPZ_T, SUMQEXPV_T, de, iflag )
implicit none
!integer, value :: Nionpm
!integer, value :: Nkvec, kxmax, kymax, kzmax
integer :: iflag
integer :: k, i
real :: dethread
real :: de(Nkvecdev)
!real :: xii(Nionpm), yii(Nionpm), zii(Nionpm)
integer :: KX(Nkvecdev), KY(NKvecdev), KZ(Nkvecdev)
!real :: ax, ay, az
!real :: charge(Nionpm)
!real :: alpha
complex :: EXPX(Nionpmdev, 0:kxmaxdev), EXPY(Nionpmdev, -kymaxdev:kymaxdev), EXPZ(Nionpmdev, -kzmaxdev:kzmaxdev)
complex :: EXPX_T(Nionpmdev, 0:kxmaxdev), EXPY_T(Nionpmdev, -kymaxdev:kymaxdev), EXPZ_T(Nionpmdev, -kzmaxdev:kzmaxdev)
complex :: SUMQEXPV(Nkvecdev)
complex :: SUMQEXPV_T(Nkvecdev)
complex :: expv_diff
integer :: kkx, kky, kkz
real :: b, ksq, CONST
k = threadidx%x
kkx = KX(k)
kky = KY(k)
kkz = KZ(k)
!calculating the constant part for a vector
ksq = axdevaxdevreal(kkxkkx) + aydevaydevreal(kkykky) + azdevazdevreal(kkz*kkz)
CONST = exp( -ksq / 4.0 / alphadev / alphadev ) / ksq
if(kkx == 0) CONST = 0.5 * CONST
de = 0.0
!SUMQEXPV_T = 0
!Looping over all the atoms in the molecule
do i = 1, Nionpmdev
b = real(kkx) * axdev * Xdevnew(i)
!write(,) b
EXPX_T(i,kkx) = cmplx( cos(b), sin(b) )
b = real(kky) * aydev * Ydevnew(i)
!write(,) b
EXPY_T(i,kky) = cmplx( cos(b), sin(b) )
EXPY_T(i,-kky) = conjg( EXPY_T(i,kky) )
b = real(kkz) * azdev * Zdevnew(i)
!write(,) b
EXPZ_T(i,kkz) = cmplx( cos(b), sin(b) )
EXPZ_T(i,-kkz) = conjg( EXPZ_T(i,kkz) )
expv_diff = EXPX_T(i,kkx) * EXPY_T(i,kky) * EXPZ_T(i,kkz) - &
EXPX(i,kkx) * EXPY(i,kky) * EXPZ(i,kkz)
SUMQEXPV_T(k) = SUMQEXPV_T(k) + expv_diff * chargedev(i)
end do
if( iflag == 0 ) then
dethread = CONST * &
( conjg( SUMQEXPV_T(k) ) * SUMQEXPV_T(k) - &
conjg( SUMQEXPV(k) ) * SUMQEXPV(k) )
else
conjg( SUMQEXPV_T(k) ) * SUMQEXPV_T(k) )
end if
call syncthreads()
!call atomicadd( de, dethread )
de(k) = dethread
end subroutine
subroutine fourier_move(mol, icb, de)
Use sp
Use ewald
Use xyz
! This routine calculates the change in the Fourier term of the
! Ewald.
integer :: mol
integer :: icb
real :: de
integer :: i, k
integer :: iflag
integer, device :: iflagdev
real :: xii, yii, zii
real :: b
!real, device, dimension(Nionpm) :: Xdev, Ydev, Zdev
real, device, allocatable, dimension(:) :: dedev
type(dim3) :: dimGrid, dimBlock
de = 0.0
if( icb < 0 ) then
iflag = 1
icb = -icb
SUMQEXPV_T(icb,:) = SUMQEXPV_T(1,:)
else
iflag = 0
SUMQEXPV_T(icb,:) = SUMQEXPV(:)
end if
EXPX_T(icb,:,0) = (1.0,0.0)
EXPY_T(icb,:,0) = (1.0,0.0)
EXPZ_T(icb,:,0) = (1.0,0.0)
! Assigning the values for device variables
allocate(dedev(Nkvec))
dedev = 0.0
do i = 1, Nionpm
Xdevnew(i) = Xi(mol,i)
Ydevnew(i) = Yi(mol,i)
Zdevnew(i) = Zi(mol,i)
EXPXdev(i,:) = EXPX(mol,i,:)
EXPYdev(i,:) = EXPY(mol,i,:)
EXPZdev(i,:) = EXPZ(mol,i,:)
end do
SUMQEXPVdev = SUMQEXPV
SUMQEXPV_Tdev(:) = SUMQEXPV_T(icb,:)
iflagdev = iflag
! Allocating the number of threads and invoking the kernel
dimGrid = dim3(1, 1, 1)
dimBlock = dim3(Nkvec, 1, 1)
call fourier_kernel<<<dimGrid,dimBlock>>>(KXdev, KYdev, KZdev, EXPXdev,&
EXPYdev, EXPZdev, SUMQEXPVdev, EXPX_Tdev, EXPY_Tdev, EXPZ_Tdev, SUMQEXPV_Tdev, dedev, iflagdev )
! Assigning the output back to the host variable
SUMQEXPV_T(icb,:) = SUMQEXPV_Tdev(:)
de = sum(dedev(1:Nkvec))
do i = 1, Nionpm
EXPX_T(icb,i,:) = EXPX_Tdev(i,:)
EXPY_T(icb,i,:) = EXPY_Tdev(i,:)
EXPZ_T(icb,i,:) = EXPZ_Tdev(i,:)
end do
de = de * 4.0 * pi / volume_e
return
end subroutine fourier_move
end module fouriercalc
Regards
Kaustubh
