Dear all:
1 : With JetPack4.4_R32.4.3, RTL8111G NIC conneted to jetson nano’s pcie0 in custom board.
2: lspci -vvv looks normal
00:01.0 PCI bridge: NVIDIA Corporation Device 0fae (rev a1) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 83
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00001000-00001fff
Memory behind bridge: 13000000-130fffff
Prefetchable memory behind bridge: 0000000020000000-00000000200fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: <access denied>
Kernel driver in use: pcieport
00:02.0 PCI bridge: NVIDIA Corporation Device 0faf (rev a1) (prog-if 00 [Normal decode])
Latency: 0
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00002000-00002fff
Memory behind bridge: fff00000-000fffff
Prefetchable memory behind bridge: 0000000020100000-00000000201fffff
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0c)
Subsystem: Realtek Semiconductor Co., Ltd. RTL8111/8168 PCI Express Gigabit Ethernet controller
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 406
Region 0: I/O ports at 1000 [size=256]
Region 2: Memory at 13000000 (64-bit, non-prefetchable) [size=4K]
Region 4: Memory at 20000000 (64-bit, prefetchable) [size=16K]
Kernel driver in use: r8168
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 19)
Interrupt: pin A routed to IRQ 407
Region 0: I/O ports at 2000 [size=256]
Region 2: Memory at 20104000 (64-bit, prefetchable) [size=4K]
Region 4: Memory at 20100000 (64-bit, prefetchable) [size=16K]
3: Both eth0 and eth1 have the same mac, and eth0 or eth1 can obtain an IP address independently and access the Internet after execution command. when I change eth1 mac, eth0 change too.
sudo /etc/init.d/network-manager restart
eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 48:b0:2d:3e:4f:ad txqueuelen 1000 (Ethernet)
RX packets 98 bytes 14675 (14.6 KB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 155 bytes 14626 (14.6 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 150 base 0xd000
eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.113 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::709c:ed3c:5299:65f prefixlen 64 scopeid 0x20<link>
RX packets 2558 bytes 1667895 (1.6 MB)
TX packets 796 bytes 84987 (84.9 KB)
device interrupt 151 base 0xa000
4: Because eth1 and eth0 both in ethernet@1003000 as follow, so i guess must be some properitys are missing.
pcie@1003000 {
/delete-property/ iommus;
/delete-property/ iommu-map;
/delete-property/ iommu-map-mask;
nvidia,wake-gpio = <&gpio TEGRA_GPIO(A, 2) 0>;
nvidia,pmc-wakeup = <&tegra_pmc
PMC_WAKE_TYPE_EVENT 0 PMC_TRIGGER_TYPE_LOW>;
avdd-pll-uerefe-supply = <&max77620_ldo7>;
hvddio-pex-supply = <&max77620_sd3>;
dvddio-pex-supply = <&max77620_ldo1>;
dvdd-pex-pll-supply = <&max77620_ldo1>;
hvdd-pex-pll-e-supply = <&max77620_sd3>;
vddio-pex-ctl-supply = <&max77620_sd3>;
status = "okay";
pci@1,0 {
#if TEGRA_XUSB_PADCONTROL_VERSION >= DT_VERSION_2
phys = <&{/xusb_padctl@7009f000/pads/pcie/lanes/pcie-1}>,
<&{/xusb_padctl@7009f000/pads/pcie/lanes/pcie-2}>,
<&{/xusb_padctl@7009f000/pads/pcie/lanes/pcie-3}>,
<&{/xusb_padctl@7009f000/pads/pcie/lanes/pcie-4}>;
phy-names = "pcie-0", "pcie-1", "pcie-2", "pcie-3";
#endif
nvidia,num-lanes = <4>;
//nvidia,plat-gpios = <&gpio TEGRA_GPIO(A, 0) GPIO_ACTIVE_HIGH>;
status = "okay";
ethernet@0,0 {
reg = <0x000000 0 0 0 0>;
pci@2,0 {
phys = <&{/xusb_padctl@7009f000/pads/pcie/lanes/pcie-0}>;
phy-names = "pcie-0";
#endif
nvidia,num-lanes = <1>;
nvidia,plat-gpios = <&gpio TEGRA_GPIO(X, 3) GPIO_ACTIVE_HIGH>;
status = "okay";
ethernet@0,0 {
Could you give me some suggestions. thanks very much.
