Issue with network driver: r8168: eth0: link down
Hi all,
I’m currently experiencing an issue with some Jetson nano devices which seem to lose connection to the router. This seems to correlate with the following error:
r8168: eth0: link up
and also, but less often this error appears:
AER: Corrected error received: id=0018
PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0010(Receiver ID)
device [10de:0faf] error status/mask=00000001/00002000
I did some research on the internet and it seems that depending on the version of the linux kernel this error seems to appear. However updating the kernel, right now is a rather lengthy process and I would like to avoid it, especially because I dont know if it will terminate the error after all. Any thoughts?
The current os on the jetsons is an ubuntu (bionic) image from balena cloud with a kernel version of 4.9.140-l4t-r32.3.1
all the best,
Glenn
This is a PCI error. Perhaps because of signal quality, perhaps because of something else. You would need to give more details on this device, and probably also the verbose output of lspci. You could log the lspci via:
sudo lspci -vvv 2>&1 | tee log_pci.txt
When something goes wrong in the kernel it is possible that one driver may cause an issue with another, but I am wondering if your PCIe card is a network card? Or is the network error one from the integrated ethernet?
Note that installing a more recent kernel is probably a long path to failure. Embedded systems have many more details to fulfill, and it isn’t too bad to back port some drivers to this release of kernel, but the reverse of going to a newer kernel on the Jetson is a lot of specialized work.
Hi Linuxdev,
thanks a lot for your answer. Here’s the output of lspci ( also I performed the same on a device that has not yet thrown this error and posted the diffs at the bottom below the results. Maybe this is beneficial):
00:02.0 PCI bridge: NVIDIA Corporation Device 0faf (rev a1) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 84
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00001000-00001fff
Memory behind bridge: fff00000-000fffff
Prefetchable memory behind bridge: 0000000020000000-00000000200fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [40] Subsystem: NVIDIA Corporation Device 0000
Capabilities: [48] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable- Count=1/2 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [60] HyperTransport: MSI Mapping Enable- Fixed-
Mapping Address Base: 00000000fee00000
Capabilities: [80] Express (v2) Root Port (Slot+), MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0
ExtTag+ RBE+
DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #1, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp-
LnkCtl: ASPM L1 Enabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
Slot #0, PowerLimit 0.000W; Interlock- NoCompl-
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Off, PwrInd On, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
Changed: MRL- PresDet+ LinkState+
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
RootCap: CRSVisible-
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR+, OBFF Not Supported ARIFwd-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled ARIFwd-
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [140 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=30us PortTPowerOnTime=70us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
T_CommonMode=30us LTR1.2_Threshold=0ns
L1SubCtl2: T_PwrOn=70us
Kernel driver in use: pcieport
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 19)
Subsystem: Realtek Semiconductor Co., Ltd. RTL8111/8168 PCI Express Gigabit Ethernet controller
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- pcilib: sysfs_read_vpd: read failed: Input/output error
Stepping- SERR- FastB2B- DisINTx+
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 407
Region 0: I/O ports at 1000 [size=256]
Region 2: Memory at 20004000 (64-bit, prefetchable) [size=4K]
Region 4: Memory at 20000000 (64-bit, prefetchable) [size=16K]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fa827000 Data: 0000
Capabilities: [70] Express (v2) Endpoint, MSI 01
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0.000W
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
MaxPayload 128 bytes, MaxReadReq 4096 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s unlimited, L1 <64us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
Capabilities: [b0] MSI-X: Enable- Count=4 Masked-
Vector table: BAR=4 offset=00000000
PBA: BAR=4 offset=00000800
Capabilities: [d0] Vital Product Data
Not readable
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq+ ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
Capabilities: [140 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
Status: NegoPending- InProgress-
Capabilities: [160 v1] Device Serial Number 00-00-00-00-00-00-00-00
Kernel driver in use: r8168
--------Diffs of healthy device-------------
ontrol: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stpcilib: sysfs_read_vpd: read failed: Input/output error
Interrupt: pin A routed to IRQ 405
Address: 00000000fa813000 Data: 0000
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
all the best,
Glenn
For now I disabled ASPM. Maybe this will change things
This shows the bridge is operating without error:
Earlier content says that the bridge throttled back to gen. 1 speeds, but this is expected since the end device the bridge works with is only capable of gen. 1 speeds, and that device is running at gen. 1.
Regarding that end device, I don’t see any error for this case:
Was the lspci performed before or after issues? If performed prior to issues, then I would not expect to see any errors. If this is the case, then you might perform the lspci steps after the system has encountered errors.
Incidentally, I feel that ASPM is an issue with a large number of devices, and difficult to debug. Disabling this is probably the right thing to do.
Ok thanks that good to know!
The lspci was performed prior to the issue. The problem is, that I effectively cannot perform it after because the system is rebooted each night and that’s when it reappears, so whatever is causing it to fail is reset during reboot. Currently, there is no way for me to access it while it’s down.
However, it seems that disabling ASPM still does not prevent the device from going offline. It might also be that there are multiple sources of errors.
Often the device prints out a link down followed by link up within the same second or 10seconds max.
The other behavior is that it simply goes offline until its rebooted and is not pingable from the router.
all the best,
Glenn
…do you mean this occurs during a reboot? Or that the error makes this unreachable and then reboot is automatic?
Is this Nano near another computer which could monitor serial console? Even another Nano could listen to the serial console, it doesn’t need to be a full PC. If this can be set up, then it’ll be much easier to debug (and this won’t depend on functioning ethernet). If the only debug is to a device which has already rebooted, then this gets much more difficult.
The problem was that the device was deployed and out in the field. It was recovered and we can now get access to it over the next days. This will be much easier.
Ill post an update as soon as I get it up and running.
Since this device was out in the field I will also suggest that during your testing you keep the power delivery as close as possible to what was out in the field. When you get results to post I’ll suggest you also describe the power supply.
