Hi all, we’ve released a utility that will update the Ethernet firmware programmed on Jetson Nano Developer Kits manufacturer prior to 5/15 (week 21 of 2019). The updated firmware corrects the following behaviors with the Ethernet port:
- Enable the RJ45 activity/link LED's
- Use the board's unique MAC address
The utility determines whether your system needs it’s firmware updated and applies new firmware only if required.
The week of manufacture can be seen in characters 4-7 of your developer kit’s Serial Number, located on the underside of the board. For example, a Serial Number of xxx1019xxxxxx indicated manufacture in the 10th week of 2019.
Download Link - https://developer.nvidia.com/embedded/dlc/jetson-nano-developer-kit-ethernet-firmware-2598410
