we use 88E1512PB2-NNP2C000 same as develop kit, the schematic diagram is the same, but doesn’t work. The dmesg error show
"eth0: Colud not attach to PHY
net eth0: eqos_open: Can’t attach to PHY (error: -19)
Hi, if the design is totally same to dev kit, it should be able to work. Otherwise it is caused by design difference or device difference. Please check and compare the design between yours and dev kit.
it’s all the same ,device and design, any debug suggestion?
Please refer to
Does the source code of develop kit’s mcu can download from website?
Only some codes(kernel/bootloader) are available over the download center.
we search all the topic and no one can slove our problem.
we can read/write the register of the phy by mdio , all the voltage seem to be right.
root@desktop:/home/cidi# dmesg | grep phy
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 4.277542] libphy: Fixed MDIO Bus: probed
[ 4.397575] libphy: dwc_phy: probed
root@desktop:/home/cidi# dmesg | grep eth0
[ 15.655204] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
When we plug in the cable with another computer , the computer port will blink for a while seems to auto negotiation, then it show connected on 10 mpbs, but xavier link show nothing and always down.
ls /sys/bus/mdio_bus/drivers , i can see the driver for 88E1512
the register data
Please share the full dmesg.
any update?
Could you compare the register value between your board and devkit?
i have done it , and it’s all the same
I can read and write(read the value is changed) the register.
When i set system internal loopback and external loopback follow marvell guide, the xavier network shows nothing changed, so does the phy chip broken?
Sloved.
We mistook a resistor, thanks for your patient
