I have configured static IP on the Jetson Orin Nano Developer Kit and I am accessing the Jetson via Remote Desktop. Sometimes, the connection gets disrupted and then reconnects after sometime on its own. I have also checked the cables, and the connections are fine. The dmesg log after disconnecting and reconnecting is below.
[ 16.910604] Adding 635840k swap on /dev/zram1. Priority:5 extents:1 across:635840k SS
[ 16.911729] zram2: detected capacity change from 0 to 651104256
[ 16.950602] Adding 635840k swap on /dev/zram2. Priority:5 extents:1 across:635840k SS
[ 16.952002] zram3: detected capacity change from 0 to 651104256
[ 16.990592] Adding 635840k swap on /dev/zram3. Priority:5 extents:1 across:635840k SS
[ 16.991765] zram4: detected capacity change from 0 to 651104256
[ 17.026602] Adding 635840k swap on /dev/zram4. Priority:5 extents:1 across:635840k SS
[ 17.027712] zram5: detected capacity change from 0 to 651104256
[ 17.066607] Adding 635840k swap on /dev/zram5. Priority:5 extents:1 across:635840k SS
[ 17.823274] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64 35.5.0 Release Build (buildbrain@mobile-u64-6519-d7000) Mon Feb 19 20:34:14 PST 2024
[ 18.074080] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[ 19.049284] r8168: eth0: link up
[ 19.049395] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 19.334809] fuse: init (API version 7.32)
[ 54.878720] r8168: eth0: link down
[ 60.041512] r8168: eth0: link up
[ 1583.742738] r8168: eth0: link down
[ 1586.857295] r8168: eth0: link up
[ 1605.278544] r8168: eth0: link down
[ 1608.361494] r8168: eth0: link up
[ 1612.446719] r8168: eth0: link down
[ 1615.561483] r8168: eth0: link up
[ 1616.574726] r8168: eth0: link down
[ 1620.681296] r8168: eth0: link up
[ 1630.910537] r8168: eth0: link down
[ 1634.025517] r8168: eth0: link up
[ 1637.086714] r8168: eth0: link down
[ 1640.169317] r8168: eth0: link up
[ 1642.206718] r8168: eth0: link down
[ 1669.897508] r8168: eth0: link up
As I have been using this for more than six months now, could it be because of the ethernet connector on the board becoming loose?
