EVGA GTX 970 SSC Overclocking does not work
the topic says it all.
I have enabled Option “28” and nvidia-settings shows the slider for fan speed and also the input fields for the memory and gpu clock offset.
BUT, the checkbox for “Enable Performance Level Editing” is missing.
Therefore i can’t apply the offsets.
Also i don’t find anything on how to adjust the vcore, it isn’t shown anywhere in nvidia-settings…
Is this a limitation in the 970 series, no overclocking yet ? (driver 346.35)
Many thanks,
Christian
No one from nvidia here to comment on that issue ?
Overvolting is only command line atm, you can only change frequency gpu/memory in nvidia-settings gui rest has to be done in terminal.
Thanks, that explains the overvolting issue. But i still miss the magic checkbox to enable memory and gpu overclocking.
I think I have the same problem, please can you try this:
nvidia-settings --query all | grep -i overvolt
for me it reports that GPUOverVoltageOffset is a read-only attribute, does it for you? It may be tied to that checkbox that I can’t find either…
