I have a Jetson NX Orin within an enclosure from Forecr and Jetpack 5.1 loaded on a m.2 SSD. It’s been fine for a month or so, but suddenly the system can only be pinged and nothing else. If I’m already accessing via SSH, then I can see the prompt but can’t do any commands, not even things like ls or ifconfig. If I reboot the system, it will be fine for another 30 mins or so. The system is passively cooled and gets warm, but not warmer than it’s been in the past, where it worked fine.
[ 7212.193103] EXT4-fs error (device nvme0n1p1): __ext4_find_entry:1534: inode #1048735: comm docker: reading directory lblock 0
[ 7215.607411] EXT4-fs warning: 35 callbacks suppressed
[ 7215.607418] EXT4-fs warning (device nvme0n1p1): dx_probe:767: inode #1572866: lblock 0: comm dbus-daemon: error -5 reading directory block
[ 7215.625396] EXT4-fs warning (device nvme0n1p1): dx_probe:767: inode #2248066: lblock 0: comm dbus-daemon: error -5 reading directory block
[ 7215.691533] EXT4-fs error: 36 callbacks suppressed
[ 7215.691538] EXT4-fs error (device nvme0n1p1): __ext4_find_entry:1534: inode #786438: comm python3: reading directory lblock 0
[ 7216.309469] EXT4-fs error (device nvme0n1p1): __ext4_find_entry:1534: inode #1048735: comm docker: reading directory lblock 0
[ 7216.365329] EXT4-fs error (device nvme0n1p1): __ext4_find_entry:1534: inode #1048735: comm gmain: reading directory lblock 0
[ 7216.636095] EXT4-fs warning (device nvme0n1p1): dx_probe:767: inode #3145729: lblock 0: comm sudo: error -5 reading directory block
[ 7216.648313] EXT4-fs warning (device nvme0n1p1): dx_probe:767: inode #3145729: lblock 0: comm sudo: error -5 reading directory block
[ 7216.660541] EXT4-fs error (device nvme0n1p1): __ext4_find_entry:1534: inode #3152181: comm sudo: reading directory lblock 0
[ 7216.672021] EXT4-fs error (device nvme0n1p1): __ext4_find_entry:1534: inode #3152181: comm sudo: reading directory lblock 0
[ 7216.683491] EXT4-fs error (device nvme0n1p1): __ext4_find_entry:1534: inode #3152181: comm sudo: reading directory lblock 0
[ 7216.694972] EXT4-fs error (device nvme0n1p1): __ext4_find_entry:1534: inode #3152181: comm sudo: reading directory lblock 0
[ 7216.706437] EXT4-fs error (device nvme0n1p1): __ext4_find_entry:1534: inode #3152181: comm sudo: reading directory lblock 0
[ 7216.709203] EXT4-fs error (device nvme0n1p1): __ext4_find_entry:1534: inode #786438: comm python3: reading directory lblock 0
[ 7216.717909] EXT4-fs error (device nvme0n1p1): __ext4_find_entry:1534: inode #3152181: comm sudo: reading directory lblock 0
[ 7216.741068] EXT4-fs warning (device nvme0n1p1): dx_probe:767: inode #2248067: lblock 0: comm sudo: error -5 reading directory block
[ 7216.753267] EXT4-fs warning (device nvme0n1p1): dx_probe:767: inode #2248067: lblock 0: comm sudo: error -5 reading directory block
[ 7216.765459] EXT4-fs warning (device nvme0n1p1): dx_probe:767: inode #2248067: lblock 0: comm sudo: error -5 reading directory block
[ 7216.777642] EXT4-fs warning (device nvme0n1p1): dx_probe:767: inode #2248067: lblock 0: comm sudo: error -5 reading directory block
[ 7216.789829] EXT4-fs warning (device nvme0n1p1): dx_probe:767: inode #2248067: lblock 0: comm sudo: error -5 reading directory block
[ 7216.802010] EXT4-fs warning (device nvme0n1p1): dx_probe:767: inode #2248067: lblock 0: comm sudo: error -5 reading directory block
[ 7220.733782] EXT4-fs error: 44 callbacks suppressed
[ 7220.733787] EXT4-fs error (device nvme0n1p1): __ext4_find_entry:1534: inode #786438: comm python3: reading directory lblock 0
[ 7221.241141] EXT4-fs warning: 31 callbacks suppressed
[ 7221.241146] EXT4-fs warning (device nvme0n1p1): dx_probe:767: inode #3145729: lblock 0: comm gmain: error -5 reading directory block
[ 7221.241167] EXT4-fs error (device nvme0n1p1): __ext4_find_entry:1534: inode #786438: comm gmain: reading directory lblock 0
[ 7221.269999] EXT4-fs error (device nvme0n1p1): __ext4_find_entry:1534: inode #786438: comm gmain: reading directory lblock 0
[ 7221.281502] EXT4-fs error (device nvme0n1p1): __ext4_find_entry:1534: inode #786438: comm gmain: reading directory lblock 0
[ 7221.455425] EXT4-fs error (device nvme0n1p1): __ext4_find_entry:1534: inode #1048735: comm docker: reading directory lblock 0
[ 7221.751458] EXT4-fs error (device nvme0n1p1): __ext4_find_entry:1534: inode #786438: comm python3: reading directory lblock 0
[ 7222.365044] EXT4-fs error (device nvme0n1p1): __ext4_find_entry:1534: inode #786438: comm gmain: reading directory lblock 0
[ 7222.376539] EXT4-fs error (device nvme0n1p1): __ext4_find_entry:1534: inode #2375046: comm gmain: reading directory lblock 0
[ 7222.388118] EXT4-fs warning (device nvme0n1p1): dx_probe:767: inode #1572866: lblock 0: comm gmain: error -5 reading directory block
[ 7222.400438] EXT4-fs error (device nvme0n1p1): __ext4_find_entry:1534: inode #1048752: comm gmain: reading directory lblock 0
[ 7222.494287] EXT4-fs error (device nvme0n1p1): __ext4_find_entry:1534: inode #1048735: comm docker: reading directory lblock 0
[ 7222.817633] EXT4-fs warning (device nvme0n1p1): dx_probe:767: inode #3145729: lblock 0: comm sudo: error -5 reading directory block
[ 7222.829869] EXT4-fs warning (device nvme0n1p1): dx_probe:767: inode #3145729: lblock 0: comm sudo: error -5 reading directory block
[ 7222.842184] EXT4-fs warning (device nvme0n1p1): dx_probe:767: inode #2248067: lblock 0: comm sudo: error -5 reading directory block
[ 7222.854369] EXT4-fs warning (device nvme0n1p1): dx_probe:767: inode #2248067: lblock 0: comm sudo: error -5 reading directory block
[ 7222.866562] EXT4-fs warning (device nvme0n1p1): dx_probe:767: inode #2248067: lblock 0: comm sudo: error -5 reading directory block
[ 7222.876322] EXT4-fs warning (device nvme0n1p1): dx_probe:767: inode #1572866: lblock 0: comm dbus-daemon: error -5 reading directory block
[ 7222.878746] EXT4-fs warning (device nvme0n1p1): dx_probe:767: inode #2248067: lblock 0: comm sudo: error -5 reading directory block
[ 7222.891616] EXT4-fs warning (device nvme0n1p1): dx_probe:767: inode #2248066: lblock 0: comm dbus-daemon: error -5 reading directory block
