I am getting below error when trying to backup the Orion NX 16 GB unit using the backup and restore script as shown below:
root@trident-B660M-AORUS-PRO-AX-DDR4:/home/trident/Downloads/r35.5.0/Linux_for_Tegra# sudo ./tools/backup_restore/l4t_backup_restore.sh -e nvme0n1 -b jetson-orion-nano-devkit
/home/trident/Downloads/r35.5.0/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash --initrd --showlogs jetson-orion-nano-devkit mmcblk0p1
/home/trident/Downloads/r35.5.0/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh: line 48: /home/trident/Downloads/r35.5.0/Linux_for_Tegra/jetson-orion-nano-devkit.conf: No such file or directory
/home/trident/Downloads/r35.5.0/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash.func: line 216: /home/trident/Downloads/r35.5.0/Linux_for_Tegra/jetson-orion-nano-devkit.conf: No such file or directory
- Step 1: Generate rcm boot commandline *
ROOTFS_AB= ROOTFS_ENC= /home/trident/Downloads/r35.5.0/Linux_for_Tegra/flash.sh --no-flash --rcm-boot jetson-orion-nano-devkit mmcblk0p1
Error: Invalid target board - jetson-orion-nano-devkit.Usage: sudo ./flash.sh [options] <target_board>
Where,
target board: Valid target board name.
rootdev: Proper root device.
options:
-c ---------- Flash partition table config file.
-d ---------- device tree file.
-f --------- Path to flash application (tegraflash.py)
-h -------------------- print this message.
-i – key for disk encryption support.
-k ----- partition name or number specified in flash.cfg.
-m ------ MTS preboot such as mts_preboot_si.
-n --------- Static nfs network assignments
-o ---------- ODM data.
-r -------------------- skip building and reuse existing system.img.
-t -------- tegraboot binary such as nvtboot.bin
-u ------ PKC key used for odm fused board.
-v ------ Secure Boot Key (SBK) key used for ODM fused board.
-w ---------- warm boot binary such as nvtbootwb0.bin
-x ---------- Tegra CHIPID.
-B ---------- BoardId.
-C ---------- Kernel commandline arguments.
WARNING:
Each option in this kernel commandline gets
higher preference over the values set by
flash.sh. In case of NFS booting, this script
adds NFS booting related arguments, if -i option
is omitted.
-F ---------- Flash server such as cboot.bin.
-G -------- Read partition and save image to file.
-I ----------- initrd file. Null initrd is default.
-K ----------- Kernel image file such as zImage or Image.
-L ------- Bootloader such as cboot.bin or u-boot-dtb.bin.
-M --------- MTS boot file such as mts_si.
-N ---------- i.e. :/my/exported/nfs/rootfs.
-R ------- Sample rootfs directory.
-S ------------- Rootfs size in bytes. Valid only for internal
rootdev. KiB, MiB, GiB short hands are allowed,
for example, 1GiB means 1024 * 1024 * 1024 bytes.
-T —The number of the sectors of the external storage device.
The default value is 122159104 if this option is not set.
-Z -------------------- Print configurations and then exit.
–no-flash ------------ perform all steps except physically flashing the board.
This will create a system.img.
–external-device------ Generate flash images for external devices
–sparseupdate--------- only flash partitions that have changed. Currently only support SPI flash memory
–no-systemimg -------- Do not create or re-create system.img.
–bup ----------------- Generate bootloader update payload(BUP).
–single-image-bup Generate specified single image BUP, this must work with --bup.
–bup-type ----- Generate specific type bootloader update payload(BUP), such as bl or kernel.
–multi-spec----------- Enable support for building multi-spec BUP.
–clean-up------------- Clean up BUP buffer when multi-spec is enabled.
–usb-instance — Specify the USB instance to connect to;
= USB port path (e.g. 3-14).
–no-root-check ------- Typical usage of this script require root permissions.
Pass this option to allow running the script as a
regular user, in which case only specific combinations
of command-line options will be functional.
–uefi-keys <keys_conf> Specify UEFI keys configuration file.
–rcm-boot ------------ Do RCM boot instead of physically flashing the board.
–sign ---------------- Sign images and store them under “bootloader/signed”
directory. The board will not be physically flashed.
–image --------------- Specify the image to be written into board.
–boot-chain-flash Flash only a specific boot chain (ex. "A, “B”, “all”).
Defaults to “all”, inputs are case insensitive.
Not suitable for production.
–boot-chain-select Specify booting chain (ex. “A” or “B”) after the board is flashed.
Defaults to “A”, inputs are case insensitive.
–pv-crt -------------- The certificate for the key that is used to sign cpu_bootloader
–with-systemimg ------ Generate system images also when using -k option
–pv-enc <enc_key>----- The encryption key that is used to encrypt cpu_bootloader.
–uefi-enc <uefi_enc_key> Key file (0x19: 16-byte; 0x23: 32-byte) to encrypt UEFI payloads
–uda-dir-------------- Directory to store user data that will be encrypted in UDA partition.
–separate-rcmboot-binary ------ Enable use of different binaries for rcmboot and coldboot.
–generic-passphrase – Use generic passphrase for disk encryption.
–disable-random-iv — Disable generation of random IV, SALT1, SALT2 and DERSTR.
–read-info ----------- Read and display board related info, fuse info (based on fuse_t234.xml),
and EEPROM content.
–reuse-uuid --------- Reuse uuid which is already generated first time.Cleaning up…
Note:
1) The same command worked for us before for our another Jetson AGX Xavier Industrial unit.
2) We observed that there is a conf file for jetson-orion-nano-devkit in that path as shown below. But it is soft linked to another file. But we dont see any permission issue for this to throw the error.
Kindly let us know, how to fix this and proceed with backup and restore.
root@trident-B660M-AORUS-PRO-AX-DDR4:/home/trident/Downloads/r35.5.0/Linux_for_Tegra# ls -l jetson*.conf
lrwxrwxrwx 1 root root 40 Feb 20 10:08 jetson-agx-orin-devkit-as-jao-32gb.conf → p3737-0000+p3701-0000-as-p3701-0004.conf
lrwxrwxrwx 1 root root 40 Feb 20 10:08 jetson-agx-orin-devkit-as-nano4gb.conf → p3737-0000+p3701-0000-as-p3767-0004.conf
lrwxrwxrwx 1 root root 40 Feb 20 10:08 jetson-agx-orin-devkit-as-nano8gb.conf → p3737-0000+p3701-0000-as-p3767-0003.conf
lrwxrwxrwx 1 root root 40 Feb 20 10:08 jetson-agx-orin-devkit-as-nx-16gb.conf → p3737-0000+p3701-0000-as-p3767-0000.conf
lrwxrwxrwx 1 root root 40 Feb 20 10:08 jetson-agx-orin-devkit-as-nx-8gb.conf → p3737-0000+p3701-0000-as-p3767-0001.conf
lrwxrwxrwx 1 root root 26 Feb 20 10:08 jetson-agx-orin-devkit.conf → p3737-0000+p3701-0000.conf
lrwxrwxrwx 1 root root 26 Feb 20 10:08 jetson-agx-orin-devkit-industrial.conf → p3737-0000+p3701-0008.conf
lrwxrwxrwx 1 root root 31 Feb 20 10:08 jetson-agx-orin-devkit-industrial-maxn.conf → p3737-0000+p3701-0008-maxn.conf
lrwxrwxrwx 1 root root 31 Feb 20 10:08 jetson-agx-orin-devkit-maxn.conf → p3737-0000+p3701-0000-maxn.conf
lrwxrwxrwx 1 root root 26 Feb 20 10:08 jetson-agx-xavier-devkit.conf → p2822-0000+p2888-0004.conf
lrwxrwxrwx 1 root root 32 Feb 20 10:08 jetson-agx-xavier-ind-noecc.conf → p2822-0000+p2888-0008-noecc.conf
lrwxrwxrwx 1 root root 26 Feb 20 10:08 jetson-agx-xavier-industrial.conf → p2822-0000+p2888-0008.conf
lrwxrwxrwx 1 root root 31 Feb 20 10:08 jetson-agx-xavier-industrial-mxn.conf → p2822-0000+p2888-0008-maxn.conf
lrwxrwxrwx 1 root root 26 Feb 20 10:08 jetson-orin-nano-devkit.conf → p3768-0000+p3767-0000.conf
lrwxrwxrwx 1 root root 31 Feb 20 10:08 jetson-orin-nano-devkit-nvme.conf → p3768-0000+p3767-0000-nvme.conf
lrwxrwxrwx 1 root root 26 Feb 20 10:08 jetson-xavier.conf → p2822-0000+p2888-0004.conf
lrwxrwxrwx 1 root root 27 Feb 20 10:08 jetson-xavier-maxn.conf → p2972-0000-devkit-maxn.conf
lrwxrwxrwx 1 root root 34 Feb 20 10:08 jetson-xavier-nx-devkit.conf → p3509-0000+p3668-0000-qspi-sd.conf
lrwxrwxrwx 1 root root 36 Feb 20 10:08 jetson-xavier-nx-devkit-emmc.conf → p3509-0000+p3668-0001-qspi-emmc.conf
lrwxrwxrwx 1 root root 31 Feb 20 10:08 jetson-xavier-nx-devkit-qspi.conf → p3509-0000+p3668-0000-qspi.conf
lrwxrwxrwx 1 root root 30 Feb 20 10:08 jetson-xavier-slvs-ec.conf → p2972-0000-devkit-slvs-ec.conf
