Extension of inbuilt wifi range for Jetson AGX Orin Developer Kit
As per the nvidia document, realtek (AW-CB375NF) is used for inbuilt wifi module on the Jetson AGX Orin Developer kit.
As per the datasheet of the module, its wifi range can be extended by connecting two physical antennas as shown in the below attached image.
Can you let us know if we can use this slots of the wifi module on the Orin developer kit for connecting external antennas to extend the range of the wifi?
Hi, the wifi module is a 3rd-party PCIe device which needs vendor to confirm. Seems it should be OK with two antennas as you said.
