Hi, our custom board used a external RTC with Xavier NX module. But after I set time into it and restart, the system seems not sync time from this rtc.
I check this rtc can hold time and I can sync time to system by command. Information is showed below
uihadmin@nvidia:~$ sudo dmesg | grep rtc
[sudo] password for uihadmin:
[ 0.471800] camchar: rtcpu character device driver loaded
[ 2.637200] tegra_rtc c2a0000.rtc: registered as rtc1
[ 2.639747] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.810455] vdd-rtc: supplied by regulator-dummy
[ 2.992662] max77686-rtc max77620-rtc: registered as rtc0
[ 3.828808] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 5
[ 3.829959] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 3.914896] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 3.915440] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.916412] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 3.917093] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 3.918880] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 3.919562] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 3.920087] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 3.921694] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (48)
[ 3.921962] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.923791] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=571b1d9f5b93980c19e16eaf250cfa6deac6f03e
[ 5.875869] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[ 5.884738] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[ 6.300139] rtc-ds1307 1-0068: registered as rtc2
[ 6.302209] rtc-ds1307 1-0068: setting system clock to 2024-05-30T01:31:44 UTC (1717032704)
uihadmin@nvidia:~$
uihadmin@nvidia:~$
uihadmin@nvidia:~$
uihadmin@nvidia:~$
uihadmin@nvidia:~$
uihadmin@nvidia:~$ date
Sat 01 Jan 2000 09:22:41 AM CST
uihadmin@nvidia:~$
uihadmin@nvidia:~$
uihadmin@nvidia:~$
uihadmin@nvidia:~$
uihadmin@nvidia:~$
uihadmin@nvidia:~$ ls -l /dev/rtc*
lrwxrwxrwx 1 root root 4 May 30 2024 /dev/rtc -> rtc2
crw------- 1 root root 250, 0 May 30 2024 /dev/rtc0
crw------- 1 root root 250, 1 May 30 2024 /dev/rtc1
crw------- 1 root root 250, 2 May 30 2024 /dev/rtc2
uihadmin@nvidia:~$
uihadmin@nvidia:~$
uihadmin@nvidia:~$ sudo hwclock -r --rtc=/dev/rtc
2024-05-30 09:36:48.332959+08:00
uihadmin@nvidia:~$
uihadmin@nvidia:~$
uihadmin@nvidia:~$
2000-01-01 09:24:55.686720+08:00
uihadmin@nvidia:~$
uihadmin@nvidia:~$
uihadmin@nvidia:~$ sudo hwclock --hctosys --rtc /dev/rtc
uihadmin@nvidia:~$
uihadmin@nvidia:~$
uihadmin@nvidia:~$
Thu 30 May 2024 09:38:05 AM CST
uihadmin@nvidia:~$
How to set to enable system can sync time from this rtc2 automaticlly?
