RTC can not save time
I am currently using jetson orin nano for testing. The RTC is powered by an external battery with a voltage of 3V. One problem is that after I use the external battery, I always have to plug and unplug the power supply of the device once and then supply power again before the device can start up normally. The following is my relevant print information
root@ubuntu:~# zcat /proc/config.gz | grep CONFIG_RTC_HCTOSYS_DEVICE
CONFIG_RTC_HCTOSYS_DEVICE=“rtc0”
root@ubuntu:~#
root@ubuntu:~# ls -al /dev/rtc*
lrwxrwxrwx 1 root root 4 Nov 21 2023 /dev/rtc → rtc1
crw------- 1 root root 249, 0 Nov 21 2023 /dev/rtc0
crw------- 1 root root 249, 1 Nov 21 2023 /dev/rtc1
root@ubuntu:~#
root@ubuntu:~#
root@ubuntu:~# dmesg | grep rtc
[ 1.260555] vdd-rtc: supplied by vdd-AO-1v2
[ 1.420149] camchar: rtcpu character device driver loaded
[ 3.923034] tegra_rtc c2a0000.rtc: registered as rtc1
[ 3.928240] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.078186] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 4.086832] nvvrs-pseq-rtc nvvrs-pseq-rtc: setting system clock to 1970-01-01T00:00:24 UTC (24)
[ 5.867697] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 6
[ 5.885612] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 5.899603] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 5.912790] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 5.973507] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 5.985470] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 5.997331] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 6.009939] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 6.022793] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 6.035069] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (112)
[ 6.041896] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 6.052772] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=23d74756c4720b2703c3fdde572be7d2b5d3d3ab
[ 6.958480] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 6.967693] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
root@ubuntu:~# vi /usr/lib/udev/rules.d/50-udev-default.rules
do not edit this file, it will be overwritten on update
select “system RTC” or just use the first one
SUBSYSTEM==“rtc”, ATTR{hctosys}==“0”, SYMLINK+=“rtc”
SUBSYSTEM==“rtc”, KERNEL==“rtc0”, SYMLINK+=“rtc”, OPTIONS+=“link_priority=-100”
Although rtc is linked to rtc1, when I set the time through hwclock, the time is always synchronized to rtc0
root@ubuntu:/home/nvidia# ls -al /dev/rtc*
root@ubuntu:/home/nvidia# sudo date -s “2025-05-13 14:30:00”
Tue 13 May 2025 02:30:00 PM PDT
root@ubuntu:/home/nvidia# hwclock -w
root@ubuntu:/home/nvidia# cat /sys/class/rtc/rtc0/date
2025-05-13
root@ubuntu:/home/nvidia# cat /sys/class/rtc/rtc1/date
1970-01-01
Duplicated with RTC cannot save time - Jetson & Embedded Systems / Jetson Orin NX - NVIDIA Developer Forums
