Extrapolate results to modern card
I’m evaluationg CUDA using my old GeForce 9600GT. I’ve created a simple test and got some result. Can someone help me to get what that result can be on new modern devices like TESLA M2090 or better.
For evaluation I generate an array of 32-bit integers and calculate count of those which contain bits specified by mask. I found out that 9600GT can handle 4 different masks over 256 MB of numbers for 180ms. What speed can be achived on modern devices?
Here is my test code:
#include <stdio.h>
const int THREADS = 512;				// Number of threads for <<<1, XXX>>> clause
const int DATASIZE = 1024*1024*256;		// Data size in bytes to process
__global__ void processPage(unsigned int * page, int * Results, int N, int mask)
	int4 * vpage = (int4*)page;
	int c = 0;
	int max = N/4;
	for ( int i = threadIdx.x; i < max; i+=THREADS )
		int4 v = vpage[i];
		if ( (v.x & mask) > 0 ) c++;
		if ( (v.y & mask) > 0 ) c++;
		if ( (v.z & mask) > 0 ) c++;
		if ( (v.w & mask) > 0 ) c++;
	Results[threadIdx.x] = c;
int N;
int Results[THREADS];
int * cResults;
unsigned int * data;
unsigned int * cData;
void initTest()
	N = DATASIZE / sizeof(int);
	cudaMalloc(&cResults, THREADS*sizeof(int));
	cudaMalloc(&cData, N*sizeof(int));
	data = (unsigned int*)malloc(N*sizeof(int));
	for ( int i = 0; i < N; i++ )
		data[i]=i;
	cudaMemcpy(cData, data, N*sizeof(int), cudaMemcpyHostToDevice);
	free(data);
int doTest(int mask)
	processPage<<<1, THREADS>>>(cData, cResults, N, mask);
	cudaMemcpy(Results, cResults, THREADS*sizeof(int), cudaMemcpyDeviceToHost);
	int c = 0;
	for ( int i = 0; i < THREADS; i++ )
		c += Results[i];
	return c;
void finishTest()
	cudaFree(&cData);
	cudaFree(&cResults);
int main()
	initTest();
	int clc = clock();
	int r
		= doTest(87234)
		+ doTest(45786)
		+ doTest(923569726)
		+ doTest(51465123);
	clc = clock()-clc;
	finishTest();
	printf("%d - %dms\n", r, (clc*1000/CLOCKS_PER_SEC));
	return 0;
On a gentoo-linux 64 bits, Tesla 2050, compiled without options, four times:
267755520 - 70ms
267755520 - 80ms
267755520 - 70ms
267755520 - 70ms
Great,
Thank you!
I would be wary of using a benchmark with only 1 block. The newer cards can (generally) run more blocks simultaneously than the old cards, so it can be hard to extrapolate based on the performance of a single block.
