On my system, this call is coming from somewhere in the JavaScript code in gnome-shell. I think this is going to have to be debugged by someone more familiar with the internals of GNOME. I see in your bug report log it says that you’re running xfce4 – if you check ps aux do you see any GNOME components running?
(gdb) bt
#0 DPMSForceLevel (dpy=0x5619d3a47ef0, level=level@entry=3) at /usr/src/debug/libXext-1.3.6-3.fc42.x86_64/src/DPMS.c:240
#1 0x00007f24400dc114 in meta_monitor_manager_xrandr_set_power_save_mode (manager=0x5619d37eb4d0, mode=<optimized out>) at ../src/backends/x11/meta-monitor-manager-xrandr.c:189
#2 meta_monitor_manager_xrandr_set_power_save_mode (manager=0x5619d37eb4d0, mode=META_POWER_SAVE_OFF) at ../src/backends/x11/meta-monitor-manager-xrandr.c:165
#3 0x00007f2440062d1f in power_save_mode_changed (manager=0x5619d37eb4d0, pspec=<optimized out>, user_data=<optimized out>) at ../src/backends/meta-monitor-manager.c:466
#4 0x00007f2440c22b1a in g_closure_invoke (closure=0x5619d3a6ba00, return_value=0x0, n_param_values=2, param_values=0x7ffe351c6b20, invocation_hint=0x7ffe351c6a70) at ../gobject/gclosure.c:833
#5 0x00007f2440c40aba in signal_emit_unlocked_R (node=node@entry=0x7ffe351c6c30, detail=detail@entry=611, instance=instance@entry=0x5619d3a31d20, emission_return=emission_return@entry=0x0, instance_and_params=instance_and_params@entry=0x7ffe351c6b20) at ../gobject/gsignal.c:3902
#6 0x00007f2440c42adc in signal_emit_valist_unlocked (instance=instance@entry=0x5619d3a31d20, signal_id=signal_id@entry=1, detail=detail@entry=611, var_args=var_args@entry=0x7ffe351c6d90) at ../gobject/gsignal.c:3534
#7 0x00007f2440c42d58 in g_signal_emit_valist (instance=0x5619d3a31d20, signal_id=1, detail=611, var_args=var_args@entry=0x7ffe351c6d90) at ../gobject/gsignal.c:3277
#8 0x00007f2440c42e13 in g_signal_emit (instance=<optimized out>, signal_id=<optimized out>, detail=<optimized out>) at ../gobject/gsignal.c:3597
#9 0x00007f2440c2ebb4 in g_object_dispatch_properties_changed (object=0x5619d3a31d20, n_pspecs=<optimized out>, pspecs=<optimized out>) at ../gobject/gobject.c:1851
#10 0x00007f2440c232fa in g_object_notify_queue_thaw (object=0x5619d3a31d20, nqueue=<optimized out>, take_ref=0) at ../gobject/gobject.c:761
#11 0x00007f2440c36b16 in g_object_setv (object=0x5619d3a31d20, n_properties=<optimized out>, names=<optimized out>, values=<optimized out>) at ../gobject/gobject.c:3110
#12 g_object_setv (object=0x5619d3a31d20, n_properties=<optimized out>, names=<optimized out>, values=<optimized out>) at ../gobject/gobject.c:3077
#13 0x00007f2440c36d41 in g_object_set_property (object=object@entry=0x5619d3a31d20, property_name=<optimized out>, value=value@entry=0x7ffe351c6ff0) at ../gobject/gobject.c:3406
#14 0x00007f24400278c1 in _meta_dbus_display_config_skeleton_handle_set_property (connection=<optimized out>, sender=<optimized out>, object_path=object_path@entry=0x7f241c182840 "/org/gnome/Mutter/DisplayConfig", interface_name=interface_name@entry=0x7f24401fd290 "org.gnome.Mutter.DisplayConfig", property_name=property_name@entry=0x5619d60de10f "PowerSaveMode", variant=variant@entry=0x5619d48234b0,
error=0x7ffe351c7080, user_data=0x5619d3a31d20) at src/meta-dbus-display-config.c:4654
#15 0x00007f244070b22b in invoke_set_property_in_idle_cb (_data=_data@entry=0x7f241c12a050) at ../gio/gdbusconnection.c:4807
#16 0x00007f2440b0e76d in g_idle_dispatch (source=0x7f241c386980, callback=0x7f244070b180 <invoke_set_property_in_idle_cb>, user_data=0x7f241c12a050) at ../glib/gmain.c:6284
#17 0x00007f2440b08040 in g_main_dispatch (context=0x5619d3663d40) at ../glib/gmain.c:3398
#18 g_main_context_dispatch_unlocked (context=0x5619d3663d40) at ../glib/gmain.c:4249
#19 0x00007f2440b11128 in g_main_context_iterate_unlocked (context=0x5619d3663d40, block=block@entry=1, dispatch=dispatch@entry=1, self=<optimized out>) at ../glib/gmain.c:4314
#20 0x00007f2440b113cf in g_main_loop_run (loop=0x5619d40f0cb0) at ../glib/gmain.c:4516
#21 0x00007f24400a415a in meta_context_run_main_loop (context=<optimized out>, error=0x7ffe351c7640) at ../src/core/meta-context.c:576
#22 0x00007f243f431056 in ffi_call_unix64 () at ../src/x86/unix64.S:104
#23 0x00007f243f42cd08 in ffi_call_int (cif=cif@entry=0x5619d415e8a0, fn=fn@entry=0x7f24400a40f0 <meta_context_run_main_loop>, rvalue=<optimized out>, rvalue@entry=0x7ffe351c7488, avalue=avalue@entry=0x5619d41da930, closure=closure@entry=0x0) at ../src/x86/ffi64.c:673
#24 0x00007f243f42f70e in ffi_call (cif=0x5619d415e8a0, fn=0x7f24400a40f0 <meta_context_run_main_loop>, rvalue=0x7ffe351c7488, avalue=0x5619d41da930) at ../src/x86/ffi64.c:710
#25 0x00007f24404c6b14 in Gjs::Function::invoke (this=0x5619d415e880, context=0x5619d368d270, args=..., this_obj=..., r_value=<optimized out>) at ../gi/function.cpp:1050
#26 0x00007f24404c744f in Gjs::Function::call (context=0x5619d368d270, js_argc=<optimized out>, vp=<optimized out>) at /usr/include/mozjs-128/js/RootingAPI.h:616
#27 0x00007f243de26972 in CallJSNative (cx=0x5619d368d270, native=0x7f24404c7380 <Gjs::Function::call(JSContext*, unsigned int, JS::Value*)>, reason=js::CallReason::Call, args=...) at /usr/src/debug/mozjs128-128.8.1-1.fc42.x86_64/js/src/vm/Interpreter.cpp:481
#28 js::InternalCallOrConstruct (cx=0x5619d368d270, args=..., construct=<optimized out>, reason=js::CallReason::Call) at /usr/src/debug/mozjs128-128.8.1-1.fc42.x86_64/js/src/vm/Interpreter.cpp:561
#29 0x00007f243de35ff1 in InternalCall (cx=0x5619d368d270, args=..., reason=<optimized out>) at /usr/src/debug/mozjs128-128.8.1-1.fc42.x86_64/js/src/vm/Interpreter.cpp:642
#30 js::CallFromStack (cx=0x5619d368d270, args=..., reason=<optimized out>) at /usr/src/debug/mozjs128-128.8.1-1.fc42.x86_64/js/src/vm/Interpreter.cpp:647
#31 js::Interpret (cx=0x5619d368d270, state=...) at /usr/src/debug/mozjs128-128.8.1-1.fc42.x86_64/js/src/vm/Interpreter.cpp:3190
#32 0x00007f243de260fc in MaybeEnterInterpreterTrampoline (cx=0x5619d3a47ef0, state=...) at /usr/src/debug/mozjs128-128.8.1-1.fc42.x86_64/js/src/vm/Interpreter.cpp:395
#33 js::RunScript (cx=0x5619d3a47ef0, state=...) at /usr/src/debug/mozjs128-128.8.1-1.fc42.x86_64/js/src/vm/Interpreter.cpp:453
#34 0x00007f243de26890 in js::InternalCallOrConstruct (cx=0x5619d368d270, args=..., construct=js::NO_CONSTRUCT, reason=<optimized out>) at /usr/src/debug/mozjs128-128.8.1-1.fc42.x86_64/js/src/vm/Interpreter.cpp:607
#35 0x00007f243de26e6c in InternalCall (cx=0x5619d3a47ef0, args=..., reason=js::CallReason::Call) at /usr/src/debug/mozjs128-128.8.1-1.fc42.x86_64/js/src/vm/Interpreter.cpp:642
#36 js::Call (cx=0x5619d3a47ef0, fval=..., thisv=..., args=..., rval=..., reason=js::CallReason::Call) at /usr/src/debug/mozjs128-128.8.1-1.fc42.x86_64/js/src/vm/Interpreter.cpp:674
#37 0x00007f243df010d2 in JS::Call (cx=0x5619d368d270, thisv=..., fval=..., args=..., rval=...) at /usr/src/debug/mozjs128-128.8.1-1.fc42.x86_64/js/src/vm/CallAndConstruct.cpp:119
#38 0x00007f2440509552 in JS::Call (cx=<optimized out>, thisv=..., funObj=..., args=..., rval=...) at /usr/include/mozjs-128/js/RootingAPI.h:1229
#39 GjsContextPrivate::run_main_loop_hook (this=0x5619d36846e0) at ../gjs/context.cpp:1399
#40 0x00007f2440511baf in GjsContextPrivate::eval_module (this=0x5619d36846e0, identifier=0x5619d40b65f0 "resource:///org/gnome/shell/ui/init.js", exit_status_p=0x7ffe351c802b "?\001", error=0x7ffe351c8030) at ../gjs/context.cpp:1516
#41 gjs_context_eval_module (js_context=<optimized out>, identifier=0x5619d40b65f0 "resource:///org/gnome/shell/ui/init.js", exit_code=0x7ffe351c802b "?\001", error=0x7ffe351c8030) at ../gjs/context.cpp:1295
#42 0x00007f2440511de1 in gjs_context_eval_module_file (js_context=js_context@entry=0x5619d3684860, filename=filename@entry=0x5619cefdb100 "resource:///org/gnome/shell/ui/init.js", exit_status_p=exit_status_p@entry=0x7ffe351c802b "?\001", error=error@entry=0x7ffe351c8030) at ../gjs/context.cpp:1600
#43 0x00005619cefd7303 in main (argc=<optimized out>, argv=<optimized out>) at ../src/main.c:691
