Extremely low bandwidth
When executing the oclBandwidthTest program from the SDK (Ubuntu 10.04 64bit), I get extremely low bandwidth on both HostToDevice and DeviceToHost.
./oclBandwidthTest Starting...
Running on...
Device GeForce 8600 GT
 Quick Mode
Host to Device Bandwidth, 1 Device(s), Paged memory, direct access
   Transfer Size (Bytes)	Bandwidth(MB/s)
   33554432			181.1
Device to Host Bandwidth, 1 Device(s), Paged memory, direct access
   33554432			197.0
Device to Device Bandwidth, 1 Device(s)
   33554432			10333.4
Anyone has any ideas as to why this happens?
–Liad Weinberger.
What does the driver tell you about PCI-E link width? Look into /var/log/Xorg.0.log, there should be a line like
(II) Aug 31 14:50:15 NVIDIA(0): Detected PCI Express Link width: 16X
I have a hunch that you are running on 1X Gen1 PCI-E or something nearly that low.
Oddly enough, you’re right, though I’m not sure how that happened. From what I recall the last time I checked, the bandwidth was fine (with an older driver). I don’t recall doing anything that might have caused this. The board specs say it has 2 PCI-E x16 slots. The card is in one of them. I’ll try moving it to the other one.
Mmmm… That actually made a difference. Now it states it found it at 16x. Running the bandwidth test gives better results, but still not what I expected:
Running on...
 Quick Mode
   33554432			1071.5
   33554432			1011.2
   33554432			10426.5
Can anyone confirm on a similar configuration? From what I know PCI-E1.0 should be closer to 4GB/s shouldn’t it?
Running on...
 Quick Mode
   33554432			1071.5
   33554432			1011.2
   33554432			10426.5
I’m getting over 2 GB/s with PCI-E 1.0 16x and a GT 240. Pinned memory improves this further to a bit over 3 GB/s.
I encountered similar bandwidth problem under Ubuntu 10.04 - but neither in host->device nor device->host region but device->device which is amazing.
Here is what I got under Win7:
C:\NVIDIA GPU Computing SDK\OpenCL\bin\Win64\Release\oclBandwidthTest.exe Starting...
Running on...
GeForce GTX 260
Quick Mode
   33554432			2006.8
   33554432			1678.1
   33554432			87479.1
PASSED
Press <Enter> to Quit...
For CUDA it is similar:
C:\NVIDIA GPU Computing SDK\C\bin\win64\Release>bandwidthTest.exe
[bandwidthTest]
bandwidthTest.exe Starting...
Running on...
Device 0: GeForce GTX 260
 Quick Mode
   33554432					 2050.5
   33554432					 1612.2
   33554432					 90653.2
[bandwidthTest] - Test results:
PASSED
And now Linux:
josef@josef:~/NVIDIA_GPU_Computing_SDK/OpenCL/bin/linux/release$ ./oclBandwidthTest
Running on...
GeForce GTX 260
Quick Mode
   33554432					 1224.5
   33554432					 1487.1
   33554432					 5030.1
PASSED
How it could be so extremely low External Image ?
I checked GPU clocking and it seems the same as in Windows.
problem solved - it had to be caused by wrong driver - I’ve reinstalled 256.40 with current Linux kernel and got good results (even better than Windows) :rolleyes:
Running on...
GeForce GTX 260
Quick Mode
   33554432					 2321.5
   33554432					 1865.4
   33554432					 91117.4
PASSED
Running on...
GeForce GTX 260
Quick Mode
   33554432			2006.8
   33554432			1678.1
   33554432			87479.1
PASSED
[bandwidthTest]
Running on...
 Quick Mode
   33554432					 2050.5
   33554432					 1612.2
   33554432					 90653.2
PASSED
And now Linux:
Running on...
GeForce GTX 260
Quick Mode
   33554432					 1224.5
   33554432					 1487.1
   33554432					 5030.1
PASSED
Running on...
GeForce GTX 260
Quick Mode
   33554432					 2321.5
   33554432					 1865.4
   33554432					 91117.4
PASSED
