Hi, i want to minimize my face recognition system from PC to Jetson nano
i use the example code from this link :
import face_recognition
import cv2
import numpy as np
# This is a demo of running face recognition on live video from your webcam. It's a little more complicated than the
# other example, but it includes some basic performance tweaks to make things run a lot faster:
# 1. Process each video frame at 1/4 resolution (though still display it at full resolution)
# 2. Only detect faces in every other frame of video.
# PLEASE NOTE: This example requires OpenCV (the `cv2` library) to be installed only to read from your webcam.
# OpenCV is *not* required to use the face_recognition library. It's only required if you want to run this
# specific demo. If you have trouble installing it, try any of the other demos that don't require it instead.
# Get a reference to webcam #0 (the default one)
video_capture = cv2.VideoCapture(0)
# Load a sample picture and learn how to recognize it.
obama_image = face_recognition.load_image_file("obama.jpg")
obama_face_encoding = face_recognition.face_encodings(obama_image)[0]
This file has been truncated. show original
the code works fine on PC. but when i move the code to Jetson nano, it can’t recognize known faces.
and i just following the guidline in this link https://medium.com/@ageitgey/build-a-hardware-based-face-recognition-system-for-150-with-the-nvidia-jetson-nano-and-python-a25cb8c891fd . to solve the dlib bug on jetson nano
when i recompile the dlib, the system still can’t recognize known faces
does anyone have experience to solve this kind of problem? thanks in advance !
the value of face encodings returned 128-dimension value and sometimes returned ‘nan’ value. and i’m using rasberry pi camera.
array when returned value:
[array([-2.71021342e+18, 5.32363354e+18, -2.49195294e+18, 8.96801266e+18... ]
array when returned nan value:
[array([nan, nan, nan, nan, nan, nan, nan, nan, nan, nan,...]
It looks like you are still having the same issue of topic_1049660 :
https://devtalk.nvidia.com/default/topic/1049660/jetson-nano/issues-with-dlib-library/2
A possible cause is that there are multiple dlib versopm in your environment and the python doesn’t use the compiled one.
Would you mind to reinstall all the dlib library first and recompile it again with the command shared above?
