Hi , I am tring to run AODT simulation mode 3 ML examples but for that most probably I need to install aerial and sionna also .I have tried to run channel_estimation.ipynb and example_pusch_simulation.ipynb but showing aerial and sionna module not found. Help me how to install them and run the example properly.
@shivshankar
Please follow this for installing pyAerial:
Getting Started with pyAerial — Aerial CUDA-Accelerated RAN
Related topics
| Facing issue in runnig AODT Simulation Mode 3 ML examples | 1 | 111 | June 5, 2025 | |
| Facing issue installing pyaerial for AODT Simulation Mode 3 - ML Examples | 1 | 124 | May 5, 2025 | |
| Inquiry on using Sionna-generated datasets in AODT without pyAerial | 6 | 316 | April 2, 2026 | |
| How to End-to-End Develop and Validate AI Models for L1 Receivers Using Sionna, the Aerial Framework, AODT, and cuBB? | 3 | 385 | July 23, 2026 | |
| Using Sionna CDL-D/E channel models with PyAerial 26.1 | 1 | 130 | July 23, 2026 | |
| How to install Sionna in pyAerial container | 0 | 136 | September 10, 2024 | |
| Most cost-effective and easiest way to run Aerial DT with a VM | 31 | 547 | August 13, 2024 | |
| AODT sim container restarting continuously | 1 | 75 | August 29, 2025 | |
| Facing some issue in AODT 1.2 “problem initializing EM solver” | 8 | 149 | June 3, 2025 | |
| Can we use PyTorch code? | 10 | 323 | December 18, 2024 |
