Hi.
Can’t install nvidia-driver-470 on desktop.
sudo apt install nvidia-driver-470
Setting up pkgconf:amd64 (1.8.1-2build1) ...
Setting up nvidia-dkms-470 (470.256.02-0ubuntu0.24.04.1) ...
update-initramfs: deferring update (trigger activated)
INFO:Enable nvidia
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
Loading new nvidia-470.256.02 DKMS files...
Building for 6.14.0-29-generic
Building for architecture x86_64
Building initial module for 6.14.0-29-generic
Error! Bad return status for module build on kernel: 6.14.0-29-generic (x86_64)
Consult /var/lib/dkms/nvidia/470.256.02/build/make.log for more information.
dpkg: error processing package nvidia-dkms-470 (--configure):
installed nvidia-dkms-470 package post-installation script subprocess returned error exit status 10
dpkg: dependency problems prevent configuration of nvidia-driver-470:
nvidia-driver-470 depends on nvidia-dkms-470 (<= 470.256.02-1); however:
Package nvidia-dkms-470 is not configured yet.
nvidia-driver-470 depends on nvidia-dkms-470 (>= 470.256.02); however:
dpkg: error processing package nvidia-driver-470 (--configure):
dependency problems - leaving unconfigured
Setting up pkg-config:amd64 (1.8.1-2build1) ...
No apport report written because the error message indicates its a followup error from a previous failure.
Setting up nvi
dia-settings (510.47.03-0ubuntu4) ...
Processing triggers for desktop-file-utils (0.27-2build1) ...
Processing triggers for gnome-menus (3.36.0-1.1ubuntu3) ...
Processing triggers for libc-bin (2.39-0ubuntu8.5) ...
Processing triggers for man-db (2.12.0-4build2) ...
Processing triggers for mailcap (3.70+nmu1ubuntu1) ...
Processing triggers for initramfs-tools (0.142ubuntu25.5) ...
update-initramfs: Generating /boot/initrd.img-6.14.0-29-generic
Errors were encountered while processing:
nvidia-dkms-470
nvidia-driver-470
E: Sub-process /usr/bin/dpkg returned an error code (1)
Installed os:
> cat /etc/lsb-release && cat /proc/version
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=24.04
DISTRIB_CODENAME=noble
DISTRIB_DESCRIPTION="Ubuntu 24.04.3 LTS"
Linux version 6.14.0-29-generic (buildd@lcy02-amd64-105) (x86_64-linux-gnu-gcc-13 (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0, GNU ld (GNU Binutils for Ubuntu) 2.42) #29~24.04.1-Ubuntu SMP PREEMPT_DYNAMIC Thu Aug 14 16:52:50 UTC 2
Please help install drivers.
make.zip (10.3 KB)
nvidia-bug-report.log.gz (102.7 KB)
