Have attempted different methods for installing NVIDIA drives on Ubuntu 24.04 but none seem to work. There are also conflicts in the results depending on which method is used. Following are the commands and responses experienced. What am I missing?
command: ubuntu-drivers install nvidia-driver-570
result: All the available drivers are already installed.
(note this was run initially and results removed with apt remove --purge ‘^nvidia-.*’)
command: apt install nvidia-driver-570 nvidia-dkms-570
result:
Reading package lists…
Building dependency tree…
Reading state information…
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help resolve the situation:
The following packages have unmet dependencies:
nvidia-driver-570 : Depends: libnvidia-compute-570 (= 570.133.07-0ubuntu0.24.04.1) but 570.144-0ubuntu0~gpu24.04.1 is to be installed
Depends: libnvidia-decode-570 (= 570.133.07-0ubuntu0.24.04.1) but it is not going to be installed
Depends: libnvidia-encode-570 (= 570.133.07-0ubuntu0.24.04.1) but it is not going to be installed
Recommends: nvidia-settings but it is not going to be installed
Recommends: nvidia-prime (>= 0.8) but it is not going to be installed
Recommends: libnvidia-compute-570:i386 (= 570.133.07-0ubuntu0.24.04.1)
Recommends: libnvidia-decode-570:i386 (= 570.133.07-0ubuntu0.24.04.1)
Recommends: libnvidia-encode-570:i386 (= 570.133.07-0ubuntu0.24.04.1)
Recommends: libnvidia-fbc1-570:i386 (= 570.133.07-0ubuntu0.24.04.1)
Recommends: libnvidia-gl-570:i386 (= 570.133.07-0ubuntu0.24.04.1)
