dukezuo
November 10, 2023, 9:04am
1
I am used r35.4.1 on orin-nano platform,I need use pcie to transmit video data over 10G size to x86 pc, So i test with the kernel pcie test driver named pcie-epf-test to test pcie(kernel-5.10\Documentation\PCI\endpoint\pci-test-howto.rst) , the pcie command is ok when i run pcitest on x86 pc,it is ok too with data tranmit not used dma, but used dma ,transmit error as blow on device:
WRITE => Size: 102400 bytes DMA: YES Time: 0.040605253 seconds Rate: 2462 KB/s
[62485.367378] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x2140020000, fsynr=0x190011, cbfrsynra=0x404, cb=0
[62485.379905] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0xffee0000, fsynr=0x4a0003, cbfrsynra=0x404, cb=0
[62485.392351] mc-err: Too many MC errors; throttling prints
[62485.397981]
WRITE => Size: 102400 bytes DMA: YES Time: 0.030608343 seconds Rate: 3267 KB/s
[62559.361767] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x2140020000, fsynr=0x190011, cbfrsynra=0x404, cb=0
[62559.374296] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0xffee0000, fsynr=0x4a0003, cbfrsynra=0x404, cb=0
[62559.386747] mc-err: unknown mcerr fault, int_status=0x00001040, ch_int_status=0x00000000, hubc_int_status=0x00000000 sbs_int_status=0x00000000, hub_int_status=0x00000000
[62559.402389]
WRITE => Size: 102400 bytes DMA: YES Time: 0.040632888 seconds Rate: 2461 KB/s
[64981.928914] tegra194-pcie 14160000.pcie_ep: LTSSM state: 0xd8 timeout: -110
[65103.166103] tegra194-pcie 14160000.pcie_ep: LTSSM state: 0xc8 timeout: -110
[65444.326018]
WRITE => Size: 102400 bytes DMA: NO Time: 0.000830611 seconds Rate: 120393 KB/s
[65490.296965]
WRITE => Size: 102400 bytes DMA: NO Time: 0.000830739 seconds Rate: 120374 KB/s
it seemd edma have some bug for kernel dma subsystem on this platform, who can help me? thanks
dukezuo
November 14, 2023, 11:01am
3
I have found sample code in file pci-epf-dma-test.c,it used paie and dma too,but it didn’t use DMA api of kernel subsystem,it control registers directly! i have some issues when i read the source:
res = platform_get_resource_byname(pdev, IORESOURCE_MEM, “atu_dma”);
epfnv->dma_base = devm_ioremap(fdev, res->start + DMA_OFFSET,
resource_size(res) - DMA_OFFSET);
but i did’t find where is “atu_dma”. who can tell me where i get the dma_base value?
kayccc
November 22, 2023, 5:43am
4
Sorry for the late response, have you managed to get issue resolved or still need the support? Thanks
dukezuo
November 22, 2023, 6:04am
5
thanks kayccc! I didn’t resoved it yet,I have edit the device tree by some other ticket:
//delete by duke 2023.11.21
//iommus = <&smmu_niso0 TEGRA_SID_NISO0_PCIE4>;
//iommu-map = <0x0 &smmu_niso0 TEGRA_SID_NISO0_PCIE4 0x1000>;
//dma-coherent;
//iommu-map-mask = <0x0>;
but when i run ,it report another error:
[ 2226.010321] pci_epf_test pci_epf_test.0: pci_epf_test_init_dma_chan dma channel id:20
[ 2433.727547] arm-smmu 12000000.iommu: Unexpected global fault, this could be serious
[ 2433.735506] arm-smmu 12000000.iommu: GFSR 0x80000002, GFSYNR0 0x00000002, GFSYNR1 0x00001013, GFSYNR2 0x00000000
[ 2433.748652] mc-err: vpr base=0:0, size=0, ctrl=1, override:(201803c6, b9ee11c1, 1, 0)
[ 2433.756761] mc-err: (255) csw_pcie4w: MC request violates VPR requirements
[ 2433.763889] mc-err: status = 0x0ff740e1; hi_addr_reg = 0x00000000 addr = 0xffffffff00
[ 2433.772130] mc-err: secure: yes, access-type: write
and i have change the config file(kernel-5.10/arch/arm64/configs/tegra_defconfig) add CONFIG_ARM_SMMU_DISABLE_BYPASS_BY_DEFAULT=y,
report the same error!
dukezuo
November 22, 2023, 11:04am
6
where is support?I am lookford to it!
dukezuo
November 28, 2023, 10:12am
7
I have run example pcie_ep_epf_dma_test on this platform,kernel crush:
) [last unloaded: mtd]
[ 1903.689720] CPU: 0 PID: 2292 Comm: cat Tainted: G W OE 5.10.120-tegra #12
[ 1903.689721] Hardware name: Unknown NVIDIA Orin Nano Developer Kit/NVIDIA Orin Nano Developer Kit, BIOS 4.1-33958178 08/01/2023
[ 1903.689723] pstate: 60400089 (nZCv daIf +PAN -UAO -TCO BTYPE=–)
[ 1903.689725] pc : tegra234_cbb_isr+0x130/0x170
[ 1903.689727] lr : tegra234_cbb_isr+0x10c/0x170
[ 1903.689729] sp : ffff800010003e10
[ 1903.689730] x29: ffff800010003e10 x28: ffff5f6d88161d80
[ 1903.689733] x27: 0000000000000001 x26: 0000000000000080
[ 1903.689736] x25: ffffdd1d4ec5a0f8 x24: ffffdd1d4f5aadd8
[ 1903.689738] x23: ffffdd1d4ef47008 x22: 0000000000000019
[ 1903.689741] x21: ffffdd1d4f3cf1e0 x20: 0000000000000002
[ 1903.689744] x19: ffffdd1d4f3cf1d0 x18: 0000000000000010
[ 1903.689746] x17: 0000000000000000 x16: ffffdd1d4d545220
[ 1903.689749] x15: ffff5f6d881622f0 x14: ffffffffffffffff
[ 1903.689752] x13: ffff800090003917 x12: ffff80001000391f
[ 1903.689754] x11: 0101010101010101 x10: 7f7f7f7f7f7f7f7f
[ 1903.689757] x9 : ffff800010003c30 x8 : 2a2a2a2a2a2a2a2a
[ 1903.689760] x7 : 2a2a2a2a2a2a2a09 x6 : c0000000ffffefff
[ 1903.689762] x5 : ffff5f6eee7b7958 x4 : ffffdd1d4f257a48
[ 1903.689765] x3 : 0000000000000000 x2 : ffffdd1d4d6e0d70
[ 1903.689769] x1 : ffff5f6d88161d80 x0 : 0000000100010000
[ 1903.689771] Call trace:
[ 1903.689775] tegra234_cbb_isr+0x130/0x170
[ 1903.689779] __handle_irq_event_percpu+0x68/0x2a0
[ 1903.689782] handle_irq_event_percpu+0x40/0xa0
[ 1903.689784] handle_irq_event+0x50/0xf0
[ 1903.689786] handle_fasteoi_irq+0xc0/0x170
[ 1903.689788] generic_handle_irq+0x40/0x60
[ 1903.689791] __handle_domain_irq+0x70/0xd0
[ 1903.689793] gic_handle_irq+0x68/0x134
[ 1903.689794] el1_irq+0xd0/0x180
[ 1903.689799] stress_test+0x1f0/0xb10 [pci_epf_dma_test]
[ 1903.689802] seq_read_iter+0x1d4/0x490
[ 1903.689804] seq_read+0xf4/0x150
[ 1903.689806] full_proxy_read+0x6c/0xa0
[ 1903.689808] vfs_read+0xb4/0x1c0
[ 1903.689810] ksys_read+0x7c/0x110
[ 1903.689812] __arm64_sys_read+0x28/0x40
[ 1903.689815] el0_svc_common.constprop.0+0x80/0x1d0
[ 1903.689817] do_el0_svc+0x38/0xb0
[ 1903.689819] el0_svc+0x1c/0x30
[ 1903.689821] el0_sync_handler+0xa8/0xb0
[ 1903.689823] el0_sync+0x16c/0x180
[ 1903.689824] —[ end trace 2c56e921df5b9794 ]—
[ 1903.694664] CPU:0, Error: cbb-fabric@0x13a00000, irq=25
[ 1903.700026] **************************************
[ 1903.704945] CPU:0, Error:cbb-fabric, Errmon:2
[ 1903.709421] Error Code : PWRDOWN_ERR
[ 1903.713443] Overflow : Multiple PWRDOWN_ERR
[ 1903.719632] Error Code : PWRDOWN_ERR
[ 1903.723653] MASTER_ID : CCPLEX
[ 1903.727141] Address : 0x36060308
[ 1903.730813] Cache : 0x1 – Bufferable
[ 1903.735104] Protection : 0x2 – Unprivileged, Non-Secure, Data Access
[ 1903.742072] Access_Type : Write
[ 1903.745656] Access_ID : 0x0
[ 1903.745658] Fabric : cbb-fabric
[ 1903.752462] Slave_Id : 0xb
[ 1903.755594] Burst_length : 0x0
[ 1903.759084] Burst_type : 0x1
[ 1903.762399] Beat_size : 0x2
[ 1903.765618] VQC : 0x0
[ 1903.768394] GRPSEC : 0x7e
[ 1903.771444] FALCONSEC : 0x0
[ 1903.774668] **************************************
[ 1903.779691] ------------[ cut here ]------------
[ 1903.779696] WARNING: CPU: 0 PID: 2292 at drivers/soc/tegra/cbb/tegra234-cbb.c:577 tegra234_cbb_isr+0x130/0x170
[ 1903.789975] Modules linked in: pci_epf_dma_test(E) fuse(E) nvidia_modeset(OE) lzo_rle(E) lzo_compress(E) zram(E) ramoops(E) reed_solomon(E) bnep(E) loop(E) aes_ce_blk(E) crypto_simd(E) cryptd(E) snd_soc_tegra186_asrc(E) aes_ce_cipher(E) rtk_btusb(E) snd_soc_tegra186_dspk(E) ghash_ce(E) snd_soc_tegra210_ope(E) snd_soc_tegra186_arad(E) snd_soc_tegra210_iqc(E) snd_soc_tegra210_mvc(E) sha2_ce(E) btusb(E) snd_soc_tegra210_adx(E) sha256_arm64(E) snd_soc_tegra210_afc(E) snd_soc_tegra210_dmic(E) snd_soc_tegra210_amx(E) rtl8822ce(E) snd_soc_tegra210_adsp(E) snd_soc_tegra210_admaif(E) btrtl(E) sha1_ce(E) snd_soc_tegra210_sfc(E) snd_soc_tegra210_mixer(E) snd_soc_tegra210_i2s(E) btbcm(E) snd_soc_tegra_pcm(E) snd_soc_tegra_machine_driver(E) snd_soc_tegra_utils(E) btintel(E) snd_soc_simple_card_utils(E) snd_soc_spdif_tx(E) snd_hda_codec_hdmi(E) nvadsp(E) fusb301(E) r8168(E) nv_imx219(E) cfg80211(E) snd_soc_tegra210_ahub(E) tegra_bpmp_thermal(E) userspace_alert(E) snd_hda_tegra(E) snd_hda_codec(E)
[ 1903.790024] tegra210_adma(E) snd_hda_core(E) nvidia(OE) spi_tegra114(E) binfmt_misc(E) ina3221(E) pwm_fan(E) nvgpu(E) nvmap(E) ip_tables(E) x_tables(E) [last unloaded: mtd]
[ 1903.790037] CPU: 0 PID: 2292 Comm: cat Tainted: G W OE 5.10.120-tegra #12
[ 1903.790038] Hardware name: Unknown NVIDIA Orin Nano Developer Kit/NVIDIA Orin Nano Developer Kit, BIOS 4.1-33958178 08/01/2023
[ 1903.790041] pstate: 60400089 (nZCv daIf +PAN -UAO -TCO BTYPE=–)
[ 1903.790043] pc : tegra234_cbb_isr+0x130/0x170
[ 1903.790045] lr : tegra234_cbb_isr+0x10c/0x170
[ 1903.790046] sp : ffff800010003e10
[ 1903.790047] x29: ffff800010003e10 x28: ffff5f6d88161d80
[ 1903.790050] x27: 0000000000000001 x26: 0000000000000080
[ 1903.790053] x25: ffffdd1d4ec5a0f8 x24: ffffdd1d4f5aadd8
[ 1903.790056] x23: ffffdd1d4ef47008 x22: 0000000000000019
[ 1903.790058] x21: ffffdd1d4f3cf1e0 x20: 0000000000000002
[ 1903.790062] x19: ffffdd1d4f3cf1d0 x18: 0000000000000010
[ 1903.790065] x17: 0000000000000000 x16: ffffdd1d4d545220
[ 1903.790068] x15: ffff5f6d881622f0 x14: ffffffffffffffff
[ 1903.790070] x13: ffff800090003917 x12: ffff80001000391f
[ 1903.790073] x11: 0101010101010101 x10: 7f7f7f7f7f7f7f7f
[ 1903.790076] x9 : ffff800010003c30 x8 : 2a2a2a2a2a2a2a2a
[ 1903.790078] x7 : 2a2a2a2a2a2a2a09 x6 : c0000000ffffefff
[ 1903.790081] x5 : ffff5f6eee7b7958 x4 : ffffdd1d4f257a48
[ 1903.790084] x3 : 0000000000000000 x2 : ffffdd1d4d6e0d70
[ 1903.790087] x1 : ffff5f6d88161d80 x0 : 0000000100010000
[ 1903.790090] Call trace:
[ 1903.790093] tegra234_cbb_isr+0x130/0x170
[ 1903.790096] __handle_irq_event_percpu+0x68/0x2a0
[ 1903.790099] handle_irq_event_percpu+0x40/0xa0
[ 1903.790102] handle_irq_event+0x50/0xf0
[ 1903.790104] handle_fasteoi_irq+0xc0/0x170
[ 1903.790106] generic_handle_irq+0x40/0x60
[ 1903.790109] __handle_domain_irq+0x70/0xd0
[ 1903.790110] gic_handle_irq+0x68/0x134
[ 1903.790112] el1_irq+0xd0/0x180
[ 1903.790116] pcie_dma_epf_exit+0xa4/0x66c [pci_epf_dma_test]
[ 1903.790118] seq_read_iter+0x1d4/0x490
[ 1903.790120] seq_read+0xf4/0x150
[ 1903.790123] full_proxy_read+0x6c/0xa0
[ 1903.790125] vfs_read+0xb4/0x1c0
[ 1903.790127] ksys_read+0x7c/0x110
[ 1903.790128] __arm64_sys_read+0x28/0x40
[ 1903.790131] el0_svc_common.constprop.0+0x80/0x1d0
[ 1903.790133] do_el0_svc+0x38/0xb0
[ 1903.790136] el0_svc+0x1c/0x30
[ 1903.790137] el0_sync_handler+0xa8/0xb0
[ 1903.790139] el0_sync+0x16c/0x180
[ 1903.790140] —[ end trace 2c56e921df5b9795 ]—
[ 1908.980198] pcie_dma_epf tegra_pcie_dma_epf.0: edma_submit_direct_txrx: DD WR CH: 0 TO
[ 1908.988422] pcie_dma_epf tegra_pcie_dma_epf.0: stress_test: DD stress failed
