Failed cuDNN 8 test (./mnistCUDNN) on Tesla K80 Ubuntu 22.04
Hi everyone. I’m trying to install CUDNN on Ubuntu 22.04 system with two Nvidia Tesla K80 GPUs totalling 24GB of GPU memory. I have installed:
  • nvidia driver 470
  • cuda toolkit 11.8
  • cudnn 8.9.7.29 (libcudnn8, libcudnn8-dev, libcudnn8-samples)
CUDA seems to have been installed properly because I could successfully compile and run the following test:
cuda-samples/Samples/1_Utilities/deviceQuery
./deviceQuery Starting...
 CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 2 CUDA Capable device(s)
Device 0: "Tesla K80"
  CUDA Driver Version / Runtime Version          11.4 / 11.8
  CUDA Capability Major/Minor version number:    3.7
  Total amount of global memory:                 11441 MBytes (11997020160 bytes)
  (013) Multiprocessors, (192) CUDA Cores/MP:    2496 CUDA Cores
  GPU Max Clock rate:                            562 MHz (0.56 GHz)
  Memory Clock rate:                             2505 Mhz
  Memory Bus Width:                              384-bit
  L2 Cache Size:                                 1572864 bytes
  Maximum Texture Dimension Size (x,y,z)         1D=(65536), 2D=(65536, 65536), 3D=(4096, 4096, 4096)
  Maximum Layered 1D Texture Size, (num) layers  1D=(16384), 2048 layers
  Maximum Layered 2D Texture Size, (num) layers  2D=(16384, 16384), 2048 layers
  Total amount of constant memory:               65536 bytes
  Total amount of shared memory per block:       49152 bytes
  Total shared memory per multiprocessor:        114688 bytes
  Total number of registers available per block: 65536
  Warp size:                                     32
  Maximum number of threads per multiprocessor:  2048
  Maximum number of threads per block:           1024
  Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
  Max dimension size of a grid size    (x,y,z): (2147483647, 65535, 65535)
  Maximum memory pitch:                          2147483647 bytes
  Texture alignment:                             512 bytes
  Concurrent copy and kernel execution:          Yes with 2 copy engine(s)
  Run time limit on kernels:                     No
  Integrated GPU sharing Host Memory:            No
  Support host page-locked memory mapping:       Yes
  Alignment requirement for Surfaces:            Yes
  Device has ECC support:                        Enabled
  Device supports Unified Addressing (UVA):      Yes
  Device supports Managed Memory:                Yes
  Device supports Compute Preemption:            No
  Supports Cooperative Kernel Launch:            No
  Supports MultiDevice Co-op Kernel Launch:      No
  Device PCI Domain ID / Bus ID / location ID:   0 / 5 / 0
  Compute Mode:
     < Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
Device 1: "Tesla K80"
  Warp size:                                     32
  Device PCI Domain ID / Bus ID / location ID:   0 / 6 / 0
  Compute Mode:
> Peer access from Tesla K80 (GPU0) -> Tesla K80 (GPU1) : Yes
> Peer access from Tesla K80 (GPU1) -> Tesla K80 (GPU0) : Yes
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 11.4, CUDA Runtime Version = 11.8, NumDevs = 2
Result = PASS
However, the following CUDDN test fails:
cudnn_samples_v8/mnistCUDNN
Executing: mnistCUDNN
cudnnGetVersion() : 8907 , CUDNN_VERSION from cudnn.h : 8907 (8.9.7)
Host compiler version : GCC 11.4.0
There are 2 CUDA capable devices on your machine :
device 0 : sms 13  Capabilities 3.7, SmClock 562.0 Mhz, MemSize (Mb) 11441, MemClock 2505.0 Mhz, Ecc=1, boardGroupID=0
device 1 : sms 13  Capabilities 3.7, SmClock 562.0 Mhz, MemSize (Mb) 11441, MemClock 2505.0 Mhz, Ecc=1, boardGroupID=0
Using device 0
Testing single precision
ERROR: cudnn failure (CUDNN_STATUS_ARCH_MISMATCH) in mnistCUDNN.cpp:414
Aborting...
I suspect it has something to do with the relatively old driver? I did try installing newer drivers like version 535 or 550, but those drivers wouldn’t work. I got a message in the log saying my GPU only runs on the 470.x legacy driver. Still, according to the documentation, the 470 driver should work with CUDA 11.x. I also tried looking for CUDNN version documentation but I couldn’t find it.
I have tried installing CUDA toolkit 11.4 too, but Ubuntu 22 lacks the required dependency. Please help me solve this issue. Thank you very much.
I tried installing the cuda-compat-11-8 package. I still could compile the cudnn sample code, but it gives the following different error:
ERROR: cuda failure (no CUDA-capable device is detected) in error_util.h:91
Aborting...
nvidia-smi and nvcc --version still print out the correct output. My .bashrc:
export CUDA_PATH=/usr/local/cuda-11.8
export LD_LIBRARY_PATH=${CUDA_PATH}/lib64:$LD_LIBRARY_PATH
export PATH=${CUDA_PATH}/bin:${PATH}
export LD_LIBRARY_PATH=${CUDA_PATH}/compat:$LD_LIBRARY_PATH
Did I install the wrong compatibility package? Since I’m trying to run CUDA 11.8, I should install cuda-compat-11-8 right?
For extra information, these are the outputs of nvidia-smi and nvcc --version.
| NVIDIA-SMI 470.239.06   Driver Version: 470.239.06   CUDA Version: 11.8     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  Tesla K80           Off  | 00000000:05:00.0 Off |                    0 |
| N/A   38C    P0    58W / 149W |      0MiB / 11441MiB |      0%      Default |
|                               |                      |                  N/A |
|   1  Tesla K80           Off  | 00000000:06:00.0 Off |                    0 |
| N/A   30C    P0    72W / 149W |      0MiB / 11441MiB |     90%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|  No running processes found                                                 |
Copyright (c) 2005-2022 NVIDIA Corporation
Built on Wed_Sep_21_10:33:58_PDT_2022
Cuda compilation tools, release 11.8, V11.8.89
Build cuda_11.8.r11.8/compiler.31833905_0
No solution. I couldn’t get the forward compatibility to work.
I ended up downgrading to Ubuntu 22.04 and installed the Nvidia 470 driver, CUDA 11.4, and CUDNN 8.2. OpenCV 4.9 also installed smoothly.
