I am trying to run CUDA 10 toolkit + CUDNN 7.5.0 with RTX 3060 GPU. I got totally stuck at CUDNN verifying.
When I run $ ./mnistCUDNN i get:
cudnnGetVersion() : 7500 , CUDNN_VERSION from cudnn.h : 7500 (7.5.0)
Host compiler version : GCC 6.5.0
There are 1 CUDA capable devices on your machine :
device 0 : sms 28 Capabilities 8.6, SmClock 1852.0 Mhz, MemSize (Mb) 12045, MemClock 7501.0 Mhz, Ecc=0, boardGroupID=0
Using device 0
Testing single precision
Loading image data/one_28x28.pgm
Performing forward propagation …
Testing cudnnGetConvolutionForwardAlgorithm …
Fastest algorithm is Algo 0
Testing cudnnFindConvolutionForwardAlgorithm …
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.001024 time requiring 100 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.009536 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.056032 time requiring 207360 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.214880 time requiring 57600 memory
^^^^ CUDNN_STATUS_NOT_SUPPORTED for Algo 3: -1.000000 time requiring 0 memory
Resulting weights from Softmax:
0.0000000 0.9999399 0.0000000 0.0000000 0.0000561 0.0000000 0.0000012 0.0000017 0.0000010 0.0000000
Loading image data/three_28x28.pgm
0.0000000 0.0000000 0.0000000 0.9999288 0.0000000 0.0000711 0.0000000 0.0000000 0.0000000 0.0000000
Loading image data/five_28x28.pgm
0.0997550 0.0892810 0.1054468 0.1071846 0.0902156 0.1043498 0.0953814 0.0938049 0.1155469 0.0990339
Result of classification: 1 3 8
Test failed!
Prediction mismatch
mnistCUDNN.cpp:876
Aborting…
Results of $ nvidia-smi :
Thu Aug 26 23:58:30 2021
| NVIDIA-SMI 470.57.02 Driver Version: 470.57.02 CUDA Version: 11.4 |
| | | MIG M. |
| 0 NVIDIA GeForce … Off | 00000000:07:00.0 On | N/A |
| 0% 40C P8 18W / 170W | 371MiB / 12045MiB | 2% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1176 G /usr/lib/xorg/Xorg 26MiB |
| 0 N/A N/A 1248 G /usr/bin/gnome-shell 88MiB |
| 0 N/A N/A 1514 G /usr/lib/xorg/Xorg 146MiB |
| 0 N/A N/A 1647 G /usr/bin/gnome-shell 27MiB |
| 0 N/A N/A 2042 G …AAAAAAAAA= --shared-files 77MiB |
And $ nvcc --version:
Copyright (c) 2005-2018 NVIDIA Corporation
Built on Sat_Aug_25_21:08:01_CDT_2018
Cuda compilation tools, release 10.0, V10.0.130
Thank you in advance for any idea that might help. I reinstalled everything several times and followed official documentation. Maybe I have missed some compatibility issues, but hopefully not.
