Hello. I have an error similar to this one, if not the exact same one.
My current setup:
OS: Ubuntu 20.04.2 LTS
CPU: Intel Core i7-7700K @ 4.20GHz
GPU: NVIDIA GeForce GTX680
Packages:
nvidia-driver-465 (465.19.01-0ubuntu1 amd64)
cuda-10-2 (10.2.89-1 amd64)
cuda-drivers-465 (465.19.01-1 amd64)
libcudnn8 (8.1.1.33-1+cuda10.2 amd64)
My install seemed to go quite well initially, but I finally got to the step where one installs cudnn and runs a test. Here is the output of make:
user@user:~/cudnn_samples_v8/mnistCUDNN$ make clean && make > make.txt
rm -rf *o
rm -rf mnistCUDNN
CUDA_VERSION is 10020
Linking agains cublasLt = true
CUDA VERSION: 10020
TARGET ARCH: x86_64
HOST_ARCH: x86_64
TARGET OS: linux
SMS: 35 50 53 60 61 62 70 72 75
/usr/local/cuda/bin/nvcc -ccbin g++ -I/usr/local/cuda/include -I/usr/local/cuda/targets/ppc64le-linux/include -IFreeImage/include -m64 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_53,code=sm_53 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_62,code=sm_62 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_72,code=sm_72 -gencode arch=compute_75,code=sm_75 -gencode arch=compute_75,code=compute_75 -o fp16_dev.o -c fp16_dev.cu
g++ -I/usr/local/cuda/include -I/usr/local/cuda/targets/ppc64le-linux/include -IFreeImage/include -o fp16_emu.o -c fp16_emu.cpp
g++ -I/usr/local/cuda/include -I/usr/local/cuda/targets/ppc64le-linux/include -IFreeImage/include -o mnistCUDNN.o -c mnistCUDNN.cpp
/usr/local/cuda/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_53,code=sm_53 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_62,code=sm_62 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_72,code=sm_72 -gencode arch=compute_75,code=sm_75 -gencode arch=compute_75,code=compute_75 -o mnistCUDNN fp16_dev.o fp16_emu.o mnistCUDNN.o -I/usr/local/cuda/include -I/usr/local/cuda/targets/ppc64le-linux/include -IFreeImage/include -L/usr/local/cuda/lib64 -L/usr/local/cuda/targets/ppc64le-linux/lib -lcublasLt -LFreeImage/lib/linux/x86_64 -LFreeImage/lib/linux -lcudart -lcublas -lcudnn -lfreeimage -lstdc++ -lm
And the output of when I try to run the binary:
user@user:~/cudnn_samples_v8/mnistCUDNN$ ./mnistCUDNN
Executing: mnistCUDNN
cudnnGetVersion() : 8101 , CUDNN_VERSION from cudnn.h : 8101 (8.1.1)
Host compiler version : GCC 8.4.0
There are 1 CUDA capable devices on your machine :
device 0 : sms 8 Capabilities 3.0, SmClock 1176.0 Mhz, MemSize (Mb) 4035, MemClock 3004.0 Mhz, Ecc=0, boardGroupID=0
Using device 0
Testing single precision
Loading binary file data/conv1.bin
Loading binary file data/conv1.bias.bin
Loading binary file data/conv2.bin
Loading binary file data/conv2.bias.bin
Loading binary file data/ip1.bin
Loading binary file data/ip1.bias.bin
Loading binary file data/ip2.bin
Loading binary file data/ip2.bias.bin
Loading image data/one_28x28.pgm
Performing forward propagation ...
Testing cudnnGetConvolutionForwardAlgorithm_v7 ...
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: -1.000000 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: -1.000000 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: -1.000000 time requiring 57600 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: -1.000000 time requiring 178432 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: -1.000000 time requiring 2057744 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: -1.000000 time requiring 184784 memory
^^^^ CUDNN_STATUS_NOT_SUPPORTED for Algo 6: -1.000000 time requiring 0 memory
^^^^ CUDNN_STATUS_NOT_SUPPORTED for Algo 3: -1.000000 time requiring 0 memory
Testing cudnnFindConvolutionForwardAlgorithm ...
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.021888 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.022016 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.044480 time requiring 57600 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.096064 time requiring 178432 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.106880 time requiring 184784 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 0.321792 time requiring 2057744 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: -1.000000 time requiring 2450080 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: -1.000000 time requiring 1433120 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: -1.000000 time requiring 4656640 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: -1.000000 time requiring 2000 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: -1.000000 time requiring 128000 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.102528 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.104288 time requiring 2000 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.116320 time requiring 2450080 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.175840 time requiring 128000 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.217952 time requiring 4656640 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 0.377984 time requiring 1433120 memory
Resulting weights from Softmax:
0.0000000 0.9999399 0.0000000 0.0000000 0.0000561 0.0000000 0.0000012 0.0000017 0.0000010 0.0000000
Loading image data/three_28x28.pgm
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.024128 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.024704 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.040352 time requiring 57600 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.097952 time requiring 178432 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.108288 time requiring 184784 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 0.309248 time requiring 2057744 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.099872 time requiring 2000 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.102304 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.117760 time requiring 2450080 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.174272 time requiring 128000 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.215392 time requiring 4656640 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 0.377184 time requiring 1433120 memory
0.0000000 0.0000000 0.0000000 0.9999288 0.0000000 0.0000711 0.0000000 0.0000000 0.0000000 0.0000000
Loading image data/five_28x28.pgm
0.0000000 0.0000008 0.0000000 0.0000002 0.0000000 0.9999820 0.0000154 0.0000000 0.0000012 0.0000006
Result of classification: 1 3 5
Test passed!
Testing half precision (math in single precision)
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: -1.000000 time requiring 28800 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: -1.000000 time requiring 100 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.029472 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.041216 time requiring 28800 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.044000 time requiring 100 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.095488 time requiring 178432 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.104864 time requiring 184784 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 0.319680 time requiring 2057744 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: -1.000000 time requiring 64000 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.109568 time requiring 2000 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.110720 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.119040 time requiring 2450080 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.170880 time requiring 64000 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.221056 time requiring 4656640 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 0.379008 time requiring 1433120 memory
nan nan nan nan nan nan nan nan nan nan
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.026496 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.040032 time requiring 28800 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.040576 time requiring 100 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.092704 time requiring 178432 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.100608 time requiring 184784 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 0.313856 time requiring 2057744 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.108128 time requiring 2000 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.111936 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.117984 time requiring 2450080 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.168896 time requiring 64000 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.218624 time requiring 4656640 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 0.371648 time requiring 1433120 memory
Result of classification: 0 0 0
Test failed!
ERROR: Prediction mismatch in mnistCUDNN.cpp:978
Aborting...
