OS: Ubuntu 18.04/ cuda 10.0/ tensorflow-gpu 1.13.1/ cudnn 7.3.0
When I want to verify the installation of cudnn through ./mnistCUDNN, it runs about 20 mins and failed like this:
cudnnGetVersion() : 7300 , CUDNN_VERSION from cudnn.h : 7300 (7.3.0)
Host compiler version : GCC 7.5.0
There are 1 CUDA capable devices on your machine :
device 0 : sms 20 Capabilities 8.6, SmClock 1485.0 Mhz, MemSize (Mb) 3910, MemClock 6001.0 Mhz, Ecc=0, boardGroupID=0
Using device 0
Testing single precision
Loading image data/one_28x28.pgm
Performing forward propagation ...
Testing cudnnGetConvolutionForwardAlgorithm ...
Fastest algorithm is Algo 0
Testing cudnnFindConvolutionForwardAlgorithm ...
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.001824 time requiring 100 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.010240 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.018432 time requiring 57600 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 4: 0.052224 time requiring 207360 memory
^^^^ CUDNN_STATUS_NOT_SUPPORTED for Algo 3: -1.000000 time requiring 0 memory
Resulting weights from Softmax:
0.0000000 0.9999399 0.0000000 0.0000000 0.0000561 0.0000000 0.0000012 0.0000017 0.0000010 0.0000000
Loading image data/three_28x28.pgm
0.0000000 0.0000000 0.0000000 0.9999288 0.0000000 0.0000711 0.0000000 0.0000000 0.0000000 0.0000000
Loading image data/five_28x28.pgm
0.0997550 0.0892810 0.1054468 0.1071846 0.0902156 0.1043498 0.0953814 0.0938049 0.1155469 0.0990339
Result of classification: 1 3 8
Test failed!
Prediction mismatch
mnistCUDNN.cpp:876
Aborting...
But when I use cat /usr/local/cuda/include/cudnn.h | grep CUDNN_MAJOR -A 2, it shows:
#define CUDNN_MAJOR 7
#define CUDNN_MINOR 3
#define CUDNN_PATCHLEVEL 0
#define CUDNN_VERSION (CUDNN_MAJOR * 1000 + CUDNN_MINOR * 100 + CUDNN_PATCHLEVEL)
#include "driver_types.h"
I installed cudnn through “Debian Local Installation”, I did:
sudo dpkg -i cudnn_package,
sudo cp cudnn* /usr/local/cuda/include
sudo cp -P libcudnn* /usr/local/cuda/lib64
sudo cp cudnn* /usr/local/cuda-10.0/include
sudo cp -P libcudnn* /usr/local/cuda-10.0/lib64
and activate them in their directionary
sudo chmod a+r cudnn*
sudo chmod a+r libcudnn*
Also, I tried apt-get like sudo apt-get install libcudnn7-doc=7.3.0.29-1+cuda10.0, they all showed libcudnn7 libcudnn-dev libcudnn-doc are the the newest version (7.3.0.29-1+cuda10.0).
I don’t know where goes wrong. Please help me!!!
Thank you in advance!
Help!!!
