I have trouble flashing the Jetson Nano B01 board after doing FC Rec. Below shows the errors I faced, hope to hear from you soon. Thanks.
After reading through some forums, I had tried changing my micro-usb wires and installing the libxml2-utils library using:
$sudo apt-get install libxml2-utils
(base) sumitrra@sumitrra-N56VZ:~/Linux_for_Tegra$ sudo ./flash.sh p3448-0000-max-spi external
L4T BSP Information:
R32 , REVISION: 4.4
Target Board Information:
Name: p3448-0000-max-spi, Board Family: t210ref, SoC: Tegra 210,
OpMode: production, Boot Authentication: ,
./tegraflash.py --chip 0x21 --applet “/home/sumitrra/Linux_for_Tegra/bootloader/nvtboot_recovery.bin” --skipuid --cmd “dump eeprom boardinfo cvm.bin”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0023 ] Generating RCM messages
[ 0.0037 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/sumitrra/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
[ 0.0055 ] RCM 0 is saved as rcm_0.rcm
[ 0.0069 ] RCM 1 is saved as rcm_1.rcm
[ 0.0069 ] List of rcm files are saved in rcm_list.xml
[ 0.0069 ]
[ 0.0070 ] Signing RCM messages
[ 0.0081 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0090 ] Assuming zero filled SBK key
[ 0.0171 ]
[ 0.0172 ] Copying signature to RCM mesages
[ 0.0189 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0209 ]
[ 0.0210 ] Boot Rom communication
[ 0.0223 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0237 ] RCM version 0X210001
[ 0.1261 ] Boot Rom communication completed
[ 1.1331 ]
[ 1.1334 ] dump EEPROM info
[ 1.1358 ] tegrarcm --oem platformdetails eeprom /home/sumitrra/Linux_for_Tegra/bootloader/cvm.bin
[ 1.1375 ] Applet version 00.01.0000
[ 1.2153 ] Saved platform info in /home/sumitrra/Linux_for_Tegra/bootloader/cvm.bin
[ 1.2920 ]
Board ID(3448) version(401)
Using UUID 555c02c0-9178-44ed-90c8-8870f32fb19d for mounting root partition.
copying bctfile(/home/sumitrra/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_lpddr4_204Mhz_P987.cfg)… done.
copying bootloader(/home/sumitrra/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
copying initrd(/home/sumitrra/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
populating kernel to rootfs… done.
populating initrd to rootfs… done.
populating /home/sumitrra/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0002-p3449-0000-b00.dtb to rootfs… done.
Making Boot image… done.
Existing sosfile(/home/sumitrra/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/home/sumitrra/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)… done.
copying cpu_bootloader(/home/sumitrra/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
copying bpffile(/home/sumitrra/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)… done.
Existing badpagefile(/home/sumitrra/Linux_for_Tegra/bootloader/badpage.bin) reused.
copying wb0boot(/home/sumitrra/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)… done.
Existing tosfile(/home/sumitrra/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
Existing eksfile(/home/sumitrra/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/sumitrra/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0002-p3449-0000-b00.dtb)… done.
Copying nv_boot_control.conf to rootfs
sed: can’t read /home/sumitrra/Linux_for_Tegra/rootfs/etc/nv_boot_control.conf: Not a directory
Skip generating system.img
Existing tbcfile(/home/sumitrra/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying tbcdtbfile(/home/sumitrra/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0002-p3449-0000-b00.dtb)… done.
copying cfgfile(/home/sumitrra/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_max-spi_p3448.xml) to flash.xml… done.
copying flasher(/home/sumitrra/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
Existing flashapp(/home/sumitrra/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl cboot.bin --bct P3448_A00_lpddr4_204Mhz_P987.cfg --odmdata 0x94000 --bldtb tegra210-p3448-0002-p3449-0000-b00.dtb --applet nvtboot_recovery.bin --cmd “flash; reboot” --cfg flash.xml --chip 0x21
saving flash command in /home/sumitrra/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/sumitrra/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0012 ] tegrasign --key None --getmode mode.txt
[ 0.0025 ] Assuming zero filled SBK key
[ 0.0027 ]
[ 0.0029 ] Generating RCM messages
[ 0.0042 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.0054 ] RCM 0 is saved as rcm_0.rcm
[ 0.0065 ] RCM 1 is saved as rcm_1.rcm
[ 0.0065 ] List of rcm files are saved in rcm_list.xml
[ 0.0065 ]
[ 0.0066 ] Signing RCM messages
[ 0.0078 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0089 ] Assuming zero filled SBK key
[ 0.0197 ]
[ 0.0199 ] Copying signature to RCM mesages
[ 0.0217 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0249 ]
[ 0.0250 ] Parsing partition layout
[ 0.0265 ] tegraparser --pt flash.xml.tmp
[ 0.0281 ]
[ 0.0282 ] Creating list of images to be signed
[ 0.0297 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.0371 ]
[ 0.0371 ] Generating signatures
[ 0.0387 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.0405 ] Assuming zero filled SBK key
[ 0.1182 ]
[ 0.1184 ] Generating br-bct
[ 0.1203 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[ 0.1217 ] Copying Sdram info from 2 to 3 set
[ 0.1252 ]
[ 0.1253 ] Updating boot device parameters
[ 0.1268 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[ 0.1286 ] Warning: No sdram params
[ 0.1291 ]
[ 0.1291 ] Updating bl info
[ 0.1307 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.1335 ]
[ 0.1336 ] Updating secondary storage information into bct
[ 0.1350 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_lpddr4_204Mhz_P987.bct
[ 0.1367 ]
[ 0.1368 ] Updating Odmdata
[ 0.1381 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0x94000
[ 0.1394 ] Warning: No sdram params
[ 0.1398 ]
[ 0.1398 ] Get Signed section of bct
[ 0.1416 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[ 0.1432 ]
[ 0.1432 ] Signing BCT
[ 0.1461 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.1475 ] Assuming zero filled SBK key
[ 0.1487 ]
[ 0.1488 ] Updating BCT with signature
[ 0.1500 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[ 0.1518 ]
[ 0.1518 ] Copying signatures
[ 0.1533 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.1610 ]
[ 0.1611 ] Updating BFS information on BCT
[ 0.1626 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
[ 0.1643 ]
[ 0.1644 ] Boot Rom communication
[ 0.1659 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
[ 0.1672 ] BootRom is not running
[ 0.2388 ]
[ 0.2390 ] Sending BCTs
[ 0.2415 ] tegrarcm --download bct P3448_A00_lpddr4_204Mhz_P987.bct
[ 0.2436 ] Applet version 00.01.0000
[ 0.3212 ] Sending bct
[ 0.3214 ] […] 100%
[ 0.4983 ]
[ 0.4984 ] Sending bootloader and pre-requisite binaries
[ 0.5008 ] tegrarcm --download ebt cboot.bin 0 0 --download rp1 tegra210-p3448-0002-p3449-0000-b00.dtb 0
[ 0.5029 ] Applet version 00.01.0000
[ 0.5771 ] Sending ebt
[ 0.5775 ] […] 100%
[ 0.6822 ] Sending rp1
[ 0.6853 ] […] 100%
[ 0.7418 ]
[ 0.7442 ] tegrarcm --boot recovery
[ 0.7454 ] Applet version 00.01.0000
[ 0.8179 ]
[ 0.8180 ] Retrieving storage infomation
[ 0.8204 ] tegrarcm --oem platformdetails storage storage_info.bin
[ 0.8223 ] Applet is not running on device. Continue with Bootloader
[ 639.7939 ]
[ 639.7964 ] tegradevflash --oem platformdetails storage storage_info.bin
[ 639.7984 ] Cboot version 00.01.0000
[ 639.8293 ] Saved platform info in storage_info.bin
[ 639.8302 ]
[ 639.8303 ] Flashing the device
[ 639.8316 ] tegradevflash --pt flash.xml.bin --storageinfo storage_info.bin --create
[ 639.8327 ] Cboot version 00.01.0000
[ 639.8767 ] Writing partition GPT with gpt.bin
[ 639.8774 ] […] 100%
[ 639.8839 ] Writing partition PT with flash.xml.bin
[ 639.9246 ] […] 100%
[ 639.9288 ] Writing partition NVC with nvtboot.bin.encrypt
[ 639.9632 ] […] 100%
[ 639.9800 ] Writing partition NVC_R with nvtboot.bin.encrypt
[ 640.0259 ] […] 100%
[ 640.0477 ] Writing partition TBC with nvtboot_cpu.bin.encrypt
[ 640.0977 ] […] 100%
[ 640.1166 ] Writing partition RP1 with tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt
[ 640.1650 ] […] 100%
[ 640.1882 ] Writing partition EBT with cboot.bin.encrypt
[ 640.2387 ] […] 100%
[ 640.2702 ] Writing partition WB0 with warmboot.bin.encrypt
[ 640.3234 ] […] 100%
[ 640.3402 ] Writing partition BPF with sc7entry-firmware.bin.encrypt
[ 640.3887 ] […] 100%
[ 640.4058 ] Writing partition TOS with tos-mon-only.img.encrypt
[ 640.4545 ] […] 100%
[ 640.4731 ] Writing partition DTB with tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt
[ 640.5226 ] […] 100%
[ 640.5466 ] Writing partition LNX with boot.img.encrypt
[ 640.5971 ] 00000004: Filesize is bigger than partition size
[ 640.6296 ]
Error: Return value 4
Command tegradevflash --pt flash.xml.bin --storageinfo storage_info.bin --create
Failed flashing t210ref.
