I’m trying to boot the Jetson TX1 with the new L4T release supporting DeepStream 4.0.1, but for some reason it fails to boot (or at least this is what I think by looking at the energy consumption of the board).
I’m using the NVIDIA’s stock development board, connected to ethernet connection with internet access and DHCP, and connected to host computer via USB. Host computer is Ubuntu 18.04 x64 and also has internet connection.
What I’ve tried:
Flash the L4T R32.2.1 and all JetPack 4.2.2 with SDK Manager. Says flash is successful.
Flash L4T R32.2.1 directly using terminal tool. Again, says flash is successful, same result as using SDK Manager.
In both cases, the board won’t give any signal it is booting, no HDMI output and power consumption doesn’t get above 3W. Not able to connect via SSH. Is there any other way you can think of to determine it is actually not booting?
I too am having troubles with the more recent revisions. I’m struggling with 32.2.3. I’m using the a01 devkit, with a very similar setup to your dev board (usb to Ubuntu 14.04 x86_64 host, and ethernet on devkit to internet). The TX1’s I’ve been working with also used to have R28 and they worked just fine then too. I really want one of the newer L4T releases because of the kexec command introduced in Linux 4.X.
I successfully got the system in recovery/flash mode, and verified that with the lsusb utility:
ryan@tetris:~/RegOS/L4T_R32.2.3$ lsusb | grep NVidia
Bus 003 Device 016: ID 0955:7721 NVidia Corp.
I then executed:
wget https://developer.nvidia.com/embedded/r32-2-3_Release_v1.0/t210ref_release_aarch64/Tegra210_Linux_R32.2.3_aarch64.tbz2
wget https://developer.nvidia.com/embedded/r32-2-3_Release_v1.0/t210ref_release_aarch64/Tegra_Linux_Sample-Root-Filesystem_R32.2.3_aarch64.tbz2
sudo tar xpf Tegra210_Linux_R32.2.3_aarch64.tbz2
sudo mv Linux_for_Tegra L4T_R32.2.3
cd L4T_R32.2.3/rootfs/
sudo tar xpf ../../Tegra_Linux_Sample-Root-Filesystem_R32.2.3_aarch64.tbz2
cd ..
sudo ./apply_binaries.sh
sudo ./flash.sh jetson-tx1 mmcblk0p1
The output of apply_binaries.sh looked good to me, but here is the output of that command if you’re interested: http://dpaste.com/2M1WMXW
Perhaps the output of flash.sh is more interesting. I had to cut out the Raw to Sparse Image conversion part of the log as then I wouldn’t be able to share the log as it is so long. I can’t imagine anyone can make sense of that much data anyway. A link to the output is here: http://dpaste.com/1JFRNWV
I also captured the output of the UART port from the TX1 during the flashing and then boot process. That log can be found here: http://dpaste.com/1FQHXB4
In that last log, I did notice some I2C and eeprom read failures. I am not sure why that would be, so I tried a different TX1 module and a different a01 devkit, but got the same result. Notice at the end of the log it says that “tegra-xudc-new 700d0000.xudc: setup request failed: -95” and then to complete the rest of the setup on /dev/ttyGS0
Not sure if you guys know this information. After rel-32, you need a HDMI monitor to configure user account and password. According to @RLC’s uart log, your system is waiting for your configuration.
[ 6.531153] Please complete system configuration setup on /dev/ttyGS0 to proceed...
However, you said HDMI have no signal. I would suggest to try different hdmi monitor first. Also, make sure there is no adapter on your hdmi (e.g. DVI-> HDMI/ VGA->HDMI/ DP-> HDMI…).
So it seems the problem is solved. Nevertheless, I suspect there might have been another issue which was causing the actual problem.
When I came back from Christmas holidays, I decided to give this another try. I tried downloading latest SDK Manager in Ubuntu 16.04 host machine, then connected Ethernet, micro USB, HDMI and power to the Jetson TX1, and flashed it. There was a difference, it was that the board is actually powering on after the flash (I can tell that because I saw the NVIDIA logo and also because of the consumption - this was not the case in the previous tries with the latest firmware, I’m not sure what was changed apart from the SDK Manager version).
But even it was powering on, I was unable to see the HDMI output after the boot, there was no other sign that it has booted, only that I already knew the IP assigned by the router via DHCP. So I was able to ping the board and I knew it was booted. Then, I followed the procedure indicated in your answer, and I was able to flash once again and login with the provided username and password.
