Hi, I can’t even start using the audio2face program, the program tries to build TensorRT but at approximately 50% ic comes up with an error saying “Failed to build TensorRT engine”
Here is the log with errors
2022-11-22 22:34:09 [412,550ms] [Error] [omni.audio2face.common.scripts.utils] Unable to build TensorRT model for: c:\users\vladi\appdata\local\ov\pkg\audio2face-2022.1.2\exts\omni.audio2face.emotion_deps\deps\audio2emotion-nets/nets\a2e_v1.3\model.onnx
2022-11-22 22:34:09 [412,570ms] [Error] [omni.audio2face.common.scripts.utils] Async Task Failed: <Task finished coro=<A2FCoreFullfaceInstance._init_a2e_processor_async() done, defined at c:\users\vladi\appdata\local\ov\pkg\audio2face-2022.1.2\exts\omni.audio2face.core\omni\audio2face\core\scripts\instance_fullface.py:463> exception=RuntimeError(“Error during running command: [‘c:\\users\\vladi\\appdata\\local\\ov\\pkg\\audio2face-2022.1.2\\exts\\omni.audio2face.inference_deps\\deps\\audio2face-inference-deps\\bin\\trtexec.exe’, ‘–onnx=c:\\users\\vladi\\appdata\\local\\ov\\pkg\\audio2face-2022.1.2\\exts\\omni.audio2face.emotion_deps\\deps\\audio2emotion-nets/nets\\a2e_v1.3\\model.onnx’, ‘–saveEngine=C:\\Users\\vladi\\AppData\\Local\\ov\\cache\\Kit\\103.1\\641148c1\\audio2emotion-nets\\a2e_v1.3\\model_device0_fp32.trt’, ‘–device=0’, ‘–explicitBatch’]”)>
2022-11-22 22:34:09 [412,571ms] [Error] [omni.audio2face.common.scripts.utils] Error: Error during running command: [‘c:\users\vladi\appdata\local\ov\pkg\audio2face-2022.1.2\exts\omni.audio2face.inference_deps\deps\audio2face-inference-deps\bin\trtexec.exe’, ‘–onnx=c:\users\vladi\appdata\local\ov\pkg\audio2face-2022.1.2\exts\omni.audio2face.emotion_deps\deps\audio2emotion-nets/nets\a2e_v1.3\model.onnx’, ‘–saveEngine=C:\Users\vladi\AppData\Local\ov\cache\Kit\103.1\641148c1\audio2emotion-nets\a2e_v1.3\model_device0_fp32.trt’, ‘–device=0’, ‘–explicitBatch’]
2022-11-22 22:34:09 [412,575ms] [Error] [omni.audio2face.common.scripts.utils] Traceback (most recent call last):
File “c:\users\vladi\appdata\local\ov\pkg\audio2face-2022.1.2\exts\omni.audio2face.common\omni\audio2face\common\scripts\utils.py”, line 129, in _done_callback
task.result()
File “c:\users\vladi\appdata\local\ov\pkg\audio2face-2022.1.2\exts\omni.audio2face.core\omni\audio2face\core\scripts\instance_fullface.py”, line 470, in _init_a2e_processor_async
await self._a2e_processor.set_network(network_fpath, network_name)
File “c:\users\vladi\appdata\local\ov\pkg\audio2face-2022.1.2\exts\omni.audio2face.emotion\omni\audio2face\emotion\scripts\processor.py”, line 141, in set_network
await self._build_and_load_network(network_path, network_name, self._device_id, self._trt_info)
File “c:\users\vladi\appdata\local\ov\pkg\audio2face-2022.1.2\exts\omni.audio2face.emotion\omni\audio2face\emotion\scripts\processor.py”, line 331, in _build_and_load_network
estimated_trt_builder_time,
File “c:\users\vladi\appdata\local\ov\pkg\audio2face-2022.1.2\exts\omni.audio2face.common\omni\audio2face\common\scripts\utils.py”, line 50, in wrapper
return await func(*args, **kwargs)
File “c:\users\vladi\appdata\local\ov\pkg\audio2face-2022.1.2\exts\omni.audio2face.inference\omni\audio2face\inference\scripts\trt_builder.py”, line 59, in prepare_and_load_trt_model
load_model_fn, input_model_fpath, trt_model_fpath, optimizer_params
File “c:\users\vladi\appdata\local\ov\pkg\audio2face-2022.1.2\exts\omni.audio2face.inference\omni\audio2face\inference\scripts\trt_builder.py”, line 81, in _build_or_rebuild_and_load_trt_model
await self._build_and_load_trt_model(load_model_fn, input_model_fpath, trt_model_fpath, optimizer_params)
File “c:\users\vladi\appdata\local\ov\pkg\audio2face-2022.1.2\exts\omni.audio2face.inference\omni\audio2face\inference\scripts\trt_builder.py”, line 87, in _build_and_load_trt_model
await self._build_trt_model(input_model_fpath, trt_model_fpath, optimizer_params)
File “c:\users\vladi\appdata\local\ov\pkg\audio2face-2022.1.2\exts\omni.audio2face.inference\omni\audio2face\inference\scripts\trt_builder.py”, line 116, in _build_trt_model
await run_cmd(cmd, cmd_name=“TRTEXEC”, progress_fn=self._build_trt_model_progress)
File “c:\users\vladi\appdata\local\ov\pkg\audio2face-2022.1.2\exts\omni.audio2face.common\omni\audio2face\common\scripts\cmd_runner.py”, line 63, in run_cmd
raise RuntimeError(“Error during running command: {}”.format(cmd))
RuntimeError: Error during running command: [‘c:\users\vladi\appdata\local\ov\pkg\audio2face-2022.1.2\exts\omni.audio2face.inference_deps\deps\audio2face-inference-deps\bin\trtexec.exe’, ‘–onnx=c:\users\vladi\appdata\local\ov\pkg\audio2face-2022.1.2\exts\omni.audio2face.emotion_deps\deps\audio2emotion-nets/nets\a2e_v1.3\model.onnx’, ‘–saveEngine=C:\Users\vladi\AppData\Local\ov\cache\Kit\103.1\641148c1\audio2emotion-nets\a2e_v1.3\model_device0_fp32.trt’, ‘–device=0’, ‘–explicitBatch’]
I’ve also tried to run the Omniverse with Administrator rights, didn’t work, run with antivirus off, also the same.
Please help :(
