Error when Building TensorRT engine (Auto-Emotion) in version 2023.2.0
I checked the following other posts for this error, but they recommend an update.
Failed to Build TensorRT Engine 1
Failed to Build TensorRT Engine 2
Failed to Build TensorRT Engine 3
Failed to Build TensorRT Engine 4
Failed to Build TensorRT Engine 5
Even on the newest version, this error appears.
The Audio2Face version is 2023.2.0, the error appears in
demo_fullface_mark.usda on an Nvidia RTX A4000 (16 GB), Ubuntu 23.04, Linux 6.2.0-39-generic, Python 3.11.4
2024-02-25 21:39:12  [Warning] [omni.audio2face.utility.scripts.utils] Waiting for A2E Network: TASK DELETED
2024-02-25 21:39:12  [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] duplicated key:'P (On Press)'
2024-02-25 21:39:12  [Warning] [omni.kit.hotkeys.core.registry]   -- Global [omni.kit.menu.utils] omni.kit.menu.edit::parent_prims.P
2024-02-25 21:39:12  [Warning] [omni.kit.hotkeys.core.registry]   -- Global [omni.audio2face.wizard-105.9.0] omni.audio2face.wizard-105.9.0::audio2face__player__play_pause.P
2024-02-25 21:39:12  [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] Cannot register Global [omni.kit.menu.utils] omni.kit.menu.edit::parent_prims.P, error code: Duplicated key definition
2024-02-25 21:39:12  [Warning] [omni.usd] Warning (secondary thread): in _ReportErrors at line 2890 of /buildAgent/work/ac88d7d902b57417/USD/pxr/usd/usd/stage.cpp -- Could not load sublayer @metrics:UnitsAdjust-160680d357780c2b3e46f33c2c8dc7d3.metricsAssembler@ of layer @/home/base_admin/.local/share/ov/pkg/deps/321b626abba810c3f8d1dd4d247d2967/exts/omni.audio2face.wizard/deps/audio2face-assets/mark/mesh/mark_fullface_model.usd@; skipping. (instantiating stage on stage @/home/base_admin/.local/share/ov/pkg/deps/321b626abba810c3f8d1dd4d247d2967/exts/omni.audio2face.wizard/assets/demo_fullface_mark.usda@ <0x7fd314064920>)
2024-02-25 21:43:42  [Warning] [omni.audio2face.utility.scripts.utils] Unable to read TRT info: /home/base_admin/.local/share/ov/pkg/deps/321b626abba810c3f8d1dd4d247d2967/exts/omni.audio2face.emotion_deps/deps/audio2emotion-nets/nets/a2e_v1.4.2/trt_info.json ; Details: [Errno 2] No such file or directory: '/home/base_admin/.local/share/ov/pkg/deps/321b626abba810c3f8d1dd4d247d2967/exts/omni.audio2face.emotion_deps/deps/audio2emotion-nets/nets/a2e_v1.4.2/trt_info.json'
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils] Unable to build TensorRT network for: /home/base_admin/.local/share/ov/pkg/deps/321b626abba810c3f8d1dd4d247d2967/exts/omni.audio2face.emotion_deps/deps/audio2emotion-nets/nets/a2e_v1.4.2/network.onnx
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils] Async Task Failed: <Task finished name='Task-901' coro=<A2FCoreFullfaceInstance._init_a2e_processor_async() done, defined at /home/base_admin/.local/share/ov/pkg/deps/321b626abba810c3f8d1dd4d247d2967/exts/omni.audio2face.core/omni/audio2face/core/scripts/instance_fullface.py:592> exception=RuntimeError("Error during running command: ['/home/base_admin/.local/share/ov/pkg/deps/321b626abba810c3f8d1dd4d247d2967/exts/omni.audio2face.inference_deps/deps/audio2face-inference-deps/bin/trtexec', '--onnx=/home/base_admin/.local/share/ov/pkg/deps/321b626abba810c3f8d1dd4d247d2967/exts/omni.audio2face.emotion_deps/deps/audio2emotion-nets/nets/a2e_v1.4.2/network.onnx', '--saveEngine=/home/base_admin/.cache/ov/Kit/105.1/c677816d/audio2emotion-nets/a2e_v1.4.2/network_device0_fp32.trt', '--device=0', '--tacticSources=-CUDNN', '--explicitBatch']")>
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils] Error: Error during running command: ['/home/base_admin/.local/share/ov/pkg/deps/321b626abba810c3f8d1dd4d247d2967/exts/omni.audio2face.inference_deps/deps/audio2face-inference-deps/bin/trtexec', '--onnx=/home/base_admin/.local/share/ov/pkg/deps/321b626abba810c3f8d1dd4d247d2967/exts/omni.audio2face.emotion_deps/deps/audio2emotion-nets/nets/a2e_v1.4.2/network.onnx', '--saveEngine=/home/base_admin/.cache/ov/Kit/105.1/c677816d/audio2emotion-nets/a2e_v1.4.2/network_device0_fp32.trt', '--device=0', '--tacticSources=-CUDNN', '--explicitBatch']
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils] Traceback (most recent call last):
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils]   File "/home/base_admin/.local/share/ov/pkg/deps/321b626abba810c3f8d1dd4d247d2967/exts/omni.audio2face.utility/omni/audio2face/utility/scripts/utils.py", line 134, in _done_callback
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils]     task.result()
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils]   File "/home/base_admin/.local/share/ov/pkg/deps/321b626abba810c3f8d1dd4d247d2967/exts/omni.audio2face.core/omni/audio2face/core/scripts/instance_fullface.py", line 608, in _init_a2e_processor_async
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils]     await self._a2e_processor.set_network(network_fpath, network_name)
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils]   File "/home/base_admin/.local/share/ov/pkg/deps/321b626abba810c3f8d1dd4d247d2967/exts/omni.audio2face.emotion/omni/audio2face/emotion/scripts/processor.py", line 286, in set_network
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils]     await self._build_and_load_network(network_path, network_name, self._trt_info)
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils]   File "/home/base_admin/.local/share/ov/pkg/deps/321b626abba810c3f8d1dd4d247d2967/exts/omni.audio2face.emotion/omni/audio2face/emotion/scripts/processor.py", line 479, in _build_and_load_network
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils]     await self._trt_builder.prepare_and_load_trt_network(
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils]   File "/home/base_admin/.local/share/ov/pkg/deps/321b626abba810c3f8d1dd4d247d2967/exts/omni.audio2face.utility/omni/audio2face/utility/scripts/utils.py", line 55, in wrapper
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils]     return await func(*args, **kwargs)
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils]   File "/home/base_admin/.local/share/ov/pkg/deps/321b626abba810c3f8d1dd4d247d2967/exts/omni.audio2face.inference/omni/audio2face/inference/scripts/trt_builder.py", line 54, in prepare_and_load_trt_network
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils]     await self._build_or_rebuild_and_load_trt_network(
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils]   File "/home/base_admin/.local/share/ov/pkg/deps/321b626abba810c3f8d1dd4d247d2967/exts/omni.audio2face.inference/omni/audio2face/inference/scripts/trt_builder.py", line 77, in _build_or_rebuild_and_load_trt_network
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils]     await self._build_and_load_trt_network(
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils]   File "/home/base_admin/.local/share/ov/pkg/deps/321b626abba810c3f8d1dd4d247d2967/exts/omni.audio2face.inference/omni/audio2face/inference/scripts/trt_builder.py", line 87, in _build_and_load_trt_network
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils]     await self._build_trt_network(input_network_fpath, trt_network_fpath, optimizer_params)
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils]   File "/home/base_admin/.local/share/ov/pkg/deps/321b626abba810c3f8d1dd4d247d2967/exts/omni.audio2face.inference/omni/audio2face/inference/scripts/trt_builder.py", line 116, in _build_trt_network
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils]     await run_cmd(cmd, cmd_name="TRTEXEC", progress_fn=self._build_trt_network_progress)
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils]   File "/home/base_admin/.local/share/ov/pkg/deps/321b626abba810c3f8d1dd4d247d2967/exts/omni.audio2face.utility/omni/audio2face/utility/scripts/cmd_runner.py", line 76, in run_cmd_in_app
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils]     await run_cmd(cmd, cmd_name, progress)
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils]   File "/home/base_admin/.local/share/ov/pkg/deps/321b626abba810c3f8d1dd4d247d2967/exts/omni.audio2face.utility/omni/audio2face/utility/scripts/cmd_runner.py", line 62, in run_cmd
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils]     raise RuntimeError("Error during running command: {}".format(cmd))
2024-02-25 21:43:49  [Error] [omni.audio2face.utility.scripts.utils] RuntimeError: Error during running command: ['/home/base_admin/.local/share/ov/pkg/deps/321b626abba810c3f8d1dd4d247d2967/exts/omni.audio2face.inference_deps/deps/audio2face-inference-deps/bin/trtexec', '--onnx=/home/base_admin/.local/share/ov/pkg/deps/321b626abba810c3f8d1dd4d247d2967/exts/omni.audio2face.emotion_deps/deps/audio2emotion-nets/nets/a2e_v1.4.2/network.onnx', '--saveEngine=/home/base_admin/.cache/ov/Kit/105.1/c677816d/audio2emotion-nets/a2e_v1.4.2/network_device0_fp32.trt', '--device=0', '--tacticSources=-CUDNN', '--explicitBatch']
Do previous versions of Audio2Face work on this machine?
Have you recently updated Audio2Face and was it working before the updates?
Can you share your full Audio2Face log which can be found here on linux: ~/.nvidia-omniverse/logs/Kit/Audio2Face?
