Hi.I have recently upgraded my OS to RH 7.5.From then I am encountering troubles in APM.
I have 2 active ports in the client machine.(server also supports 2 ports).These ports are passively bonded.(Only primary path will be used for data transfer)
APM : mlx4_1 - IB device - port 1 - state active and lid 23
APM : mlx4_1 - IB device - port 2 - state active and lid 26
When I try to establish a connection.I always modify the QP state from MIGRATED to REARM if APM is supported.In this case the QP state was in MIGRATED state.It has valid **alt_ah_attr.**dlid as well
[QP state = RTS mig state = MIGRATED]
altport = 1 alt_pbits = 0 altdlid = 33
When I call ibv_modify_qp with IBV_MIG_REARM ,it is throwing the Invalid argument (22) error. I am pretty sure the the arguments passed to the function are correct and worked properly in past.
What can be the reason for this?
