I followed the official guide on the ubuntu website on installing ubuntu 22.04 on jetson orin nano, but I got this message after installing cuda when running nvidia-smi: “Failed to initialize NVML: Driver/Library version mismatch
NVML library version: 540.03”
Could you share which document you follow so we can know more about the issue?
Please note that you can find the L4T image from JetPack which is also based on Ubuntu 22.04:
I followed this document https://pages.ubuntu.com/rs/066-EOV-335/images/Ubuntu_22.04_for_NVIDIA_Jetson_Orin_Instructions.pdf?version=0
Could you setup the device with JetPack to get our standard release?
We have verified the JetPack OS (which is also based on Ubuntu 22.02) and it should work on Jetson.
This seems to be related to this issue. We are working on a proper solution and will provide a workaround soon. In the meantime, as suggested above, you can try to use Jetpack 6
