Dear Community,
I’m new to BlueField and mlx5 driver. When I went through with the DOCA simple_fwd_vnf application instruction, I got this error in running.
root@localhost:/opt/mellanox/doca/applications/simple_fwd_vnf/bin# ./doca_simple_fwd_vnf -a auxiliary:mlx5_core.sf.2,dv_flow_en=2 -a auxiliary:mlx5_core.sf.3,dv_flow_
en=2 -- -l 60
EAL: Detected CPU lcores: 8
EAL: Detected NUMA nodes: 1
EAL: Detected shared linkage of DPDK
EAL: Multi-process socket /var/run/dpdk/rte/mp_socket
EAL: Selected IOVA mode 'PA'
TELEMETRY: No legacy callbacks, legacy socket not created
[18:14:53:376188][900825][DOCA][DBG][dpdk_utils.c:440][port_init] Port 0 MAC: 02 2c bc 75 fc 33
[18:14:53:414869][900825][DOCA][DBG][dpdk_utils.c:440][port_init] Port 1 MAC: 02 75 0b 78 80 a7
[18:14:53:420687][900825][DOCA][WRN][engine_model.c:74][adapt_queue_depth] adapting queue depth to 128.
mlx5_net: [mlx5dr_cmd_header_modify_pattern_create]: Failed to create header_modify_pattern (syndrome: 0x6c1bf)
mlx5_net: [mlx5dr_pat_get_pattern]: Failed to create pattern FW object
mlx5_net: [mlx5dr_action_create_modify_header_hws]: Failed to allocate pattern for modify header
mlx5_net: [mlx5dr_action_create_nat64_copy_state]: Failed to create copy for NAT64: action_sz: 56, flags: 0x48
mlx5_net: [mlx5dr_action_create_nat64]: Nat64 failed creating copy state
mlx5_net: Cannot create NAT64 action on port 0, please check the FW version
mlx5_net: Cannot create NAT64 action on port 1, please check the FW version
mlx5_net: [mlx5dr_table_set_default_miss_not_valid]: Default miss table is not supported
[18:14:57:096347][900825][DOCA][ERR][dpdk_port.c:1139][dpdk_port_group_set_miss_actions] Could not set group miss actions - message (type 1: Failed to set group miss actions)
[18:14:57:134184][900825][DOCA][ERR][dpdk_port.c:1139][dpdk_port_group_set_miss_actions] Could not set group miss actions - message (type 1: Failed to set group miss actions)
mlx5_net: [mlx5dr_definer_conv_items_to_hl]: Failed processing item type: 20
mlx5_net: [mlx5dr_definer_calc_layout]: Failed to convert items to header layout
mlx5_net: [mlx5dr_definer_matcher_init]: Failed to calculate matcher definer layout
mlx5_net: [mlx5dr_matcher_bind_mt]: Failed to set matcher templates with match definers
mlx5_net: [mlx5dr_matcher_create]: Failed to initialise matcher: 95
[18:14:57:147807][900825][DOCA][ERR][dpdk_table.c:1114][flow_template_table_create] Could not create table template - message (type 1: Failed to create template table)
[18:14:57:147883][900825][DOCA][ERR][dpdk_table.c:1518][dpdk_table_create] failed to create table reference for port 0
[18:14:57:147968][900825][DOCA][ERR][dpdk_pipe_legacy.c:882][_internal_pipe_create] failed creating pipe of type 0 - submit, rc=-12
[18:14:57:148006][900825][DOCA][ERR][dpdk_pipe_legacy.c:898][_internal_pipe_create] failed to create pipe GTP_FWD, rc=-12
[18:14:57:151703][900825][DOCA][ERR][engine_pipe.c:466][engine_pipe_create] failed creating pipe - lower layer returned null handler
[18:14:57:151781][900825][DOCA][ERR][doca_flow.c:1756][doca_flow_pipe_create] engine pipe creation failed, rc = -12
[18:14:57:151823][900825][DOCA][ERR][simple_fwd.c:873][simple_fwd_init_ports_and_pipes] Failed building GTPU pipe
[18:14:57:151924][900825][DOCA][ERR][simple_fwd_vnf.c:142][main] VNF application init error
[18:14:58:946722][900825][DOCA][DBG][dpdk_utils.c:994][dpdk_fini] DPDK fini is done
My firmware version is 24.35.2000, DOCA version is 2.6.0 and BSP_4.6.0. I set up the sf as simple_fwd_vnf design figure:
ovs-vsctl show
7e2f391e-5dd8-4225-a899-6127a6ef01da
Bridge ovsbr1
Port en3f0pf0sf2
Interface en3f0pf0sf2
Port p0
Interface p0
Port ovsbr1
Interface ovsbr1
type: internal
Bridge ovsbr2
Port ovsbr2
Interface ovsbr2
type: internal
Port pf0hpf
Interface pf0hpf
Port en3f1pf1sf3
Interface en3f1pf1sf3
ovs_version: "2.17.8+nvidia.e92ac078d"
Could anyone give hints on solving this? Thanks!
